NEED HELP B16A SWAP INTO 91 CRX
Old Dec 4, 2007 | 05:04 PM
10RPILOT's Avatar
Default NEED HELP B16A SWAP INTO 91 CRX
I just finished motor n tranny swap I have spark, fuel, and power to my injectors but it won't run? Also my check engine lite is staying on. Does anyone have any suggestions? A wiring schematics? Any help is greatly appreciated! Thanks!!
Old Dec 4, 2007 | 05:25 PM
ek4shizzle's Avatar
Default Re: NEED HELP B16A SWAP INTO 91 CRX (10RPILOT)
obd0 or obd1? see what code its throwing.
Old Dec 4, 2007 | 05:41 PM
10RPILOT's Avatar
Default Re: NEED HELP B16A SWAP INTO 91 CRX (ek4shizzle)
its an OBD1 2nd gen. I gotta check and see what codes it throws.
Old Dec 5, 2007 | 05:29 PM
10RPILOT's Avatar
ok i just checked codes and its throwing a code 6 which im pretty sure is the coolant temp
Old Dec 5, 2007 | 06:31 PM
averyvm's Avatar
I hope everything gets sorted out
Old Dec 5, 2007 | 07:23 PM
ek4shizzle's Avatar
Default Re: NEED HELP B16A SWAP INTO 91 CRX (averyvm)
check everything over. check ALL ground wires. make sure it has good connection. make sure distributer is on correctly. timing. ecu. too much to list. do a compression test to make sure you didnt swap in a jacked up motor.
Old Dec 5, 2007 | 08:54 PM
10RPILOT's Avatar
I just figured it out!!!! You all aren't gonna believe this **** but from sitting all four
fuel injectors were stuck!!!! After me any my buddy pulled them all out and ran injector cleaner threw them while working the needles put them back in and she fired up!!!! Thank freakin god!!!! thanks for all the help guys!!!!!!!
Tensa_Zangetsu
Feb 28, 2009 05:12 PM
psycho.chicken
Jul 16, 2006 08:39 AM
AllMotor_B20_Hatch
Feb 6, 2005 07:27 PM
