what kind of mods can i do with a budget of $200 dollars?
i recently buoght a 1990 dx and i was wondering what can i do to the engine with a budget of $200 dollars? can anyone tell me
None of the above. Replace worn out items ball joints, belts, oil, fluids, brakes, lights, weather stripping, etc. Do maintenance before you start doing any "mods" that is the best advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">None of the above. Replace worn out items ball joints, belts, oil, fluids, brakes, lights, weather stripping, etc. Do maintenance before you start doing any "mods" that is the best advice.</TD></TR></TABLE> Maintenance is expensive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce »</TD></TR><TR><TD CLASS="quote">For a tuneup done by self = max $116 </TD></TR></TABLE> Finding out everything else is 15+ years old and needs to replaced: priceless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Allday07 »</TD></TR><TR><TD CLASS="quote">if the car doesnt need a tune up, def hit up that mpfi swap
DPFI is like driving a fcukin carb
And what is wrong with carbs?
</TD></TR></TABLE>And what is wrong with carbs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane »</TD></TR><TR><TD CLASS="quote">
And what is wrong with carbs?</TD></TR></TABLE> they are dirt cheap and easy to tune.
But since they arn't cutting edge they suck
DPI is like the down sides of EFI and carbs mixed to one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Allday07 »</TD></TR><TR><TD CLASS="quote">nothings wrong with carbs, well..
they suck..unless its a 5.0 with a 850cfm or something, not a civic
</TD></TR></TABLE> You've got to be kidding me, least I hope.
Side draft webbers + honda = fun fun.
</TD></TR></TABLE> You've got to be kidding me, least I hope.Side draft webbers + honda = fun fun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper »</TD></TR><TR><TD CLASS="quote">
Thats what I was thinking even though Ive never had the pleasure of owning a honduh with side drafts. Maybe with my next project.
</TD></TR></TABLE>Thats what I was thinking even though Ive never had the pleasure of owning a honduh with side drafts. Maybe with my next project.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Allday07 »</TD></TR><TR><TD CLASS="quote">lol i edited my comment, didnt want to start up a war on carbs </TD></TR></TABLE> lol it's ok, I have efi on my honda now for now
I'm a die hard carb guy when it comes to toys.
They just are fun
They just are fun
how much hp would i gain if i do the mpfi swap? how does it feel a little difference at all? if not then ill just go with a b18a1 swap maybe that will be a difference any one think
I think you'll see at about 10 hp increase. Which aint bad for under 200. You will notice the difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si-Samuri »</TD></TR><TR><TD CLASS="quote">You won't be pleased unless you go v-tec. even if its dual cams. your better off with a 1 cam slam plus itll prob cost less to convert.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician »</TD></TR><TR><TD CLASS="quote">I think you'll see at about 10 hp increase. Which aint bad for under 200. You will notice the difference</TD></TR></TABLE> It really brings the motor up to the same specifications as the D15B7
