oil leaking into spark plug tube, seals already raplace but still happen
Old Dec 4, 2007 | 03:18 PM
B16A JDM EG's Avatar
Default oil leaking into spark plug tube, seals already raplace but still happen
i have a b16, i bought a complete valve cover gasket set. tube seals were replaced. still getting oil into spark plugs when the car sets over a period of time, causing my car to mis fire in till the car gets all the oil out of the spark plugs. anyone know what might be causing it?
Old Dec 4, 2007 | 03:42 PM
BUDtoker's Avatar
Default Re: oil leaking into spark plug tube, seals already raplace but still happen (B16A JDM EG)
warped head possibly or warped valve cover try buyin a new valve cover see if the helps.also check your new o rings that you just put in make sure they are not scored or scratched up !! thats all i can think of good luck..... maybe the auto zone guy gave you the wrong gasket??? that happened to me before
Old Dec 4, 2007 | 03:44 PM
i bought the gasket set off of import RP, who is a sponsor on here. i guess i can take the valve cover off and try to find out what might be happening.
Acura_DreamiN
Oct 26, 2010 07:23 PM
skaternak
Oct 2, 2008 10:32 PM
88CRX-CRB-UT
Aug 1, 2007 06:09 AM
CalhounBoi
Oct 1, 2006 05:25 PM
froger
Feb 3, 2005 12:39 PM
