cel code 17 VSS - speed sensor!!!!!! need help
Old Dec 4, 2007 | 11:49 AM
themex77's Avatar
Default cel code 17 VSS - speed sensor!!!!!! need help
ok so when out and tryed to turn on my car and nothing no crank the battery had enough charge 2 crank at least once but nothing so kick started it and it was fine then i was driving down da road and it gave me code 17 i got home parked it then tried 2 turn it on like 10 sec later and nothing samething no crank or nothing not sure whats wrong any ideas???? if it is my VSS then how do i check it???
thanks
p.s seached and really couldnt find anything similiar 2 my problem
thanks again
Old Dec 4, 2007 | 12:05 PM
Jdmefsir12's Avatar
Default Re: cel code 17 VSS - speed sensor!!!!!! need help (themex77)
wat yr car wat model wat motor hydro ? cable ? wat do u have
Old Dec 4, 2007 | 12:08 PM
themex77's Avatar
Default Re: cel code 17 VSS - speed sensor!!!!!! need help (Jdmefsir12)
its a 90 crx with a b16 and its 0db0 and its cable
thanks
Old Dec 4, 2007 | 01:44 PM
crxfreak1117's Avatar
code 17=vehicle speed sensor (vss) when u was driving did ur speedo work?
if not then there is ur problem it could have slipped out the gauge cluster or came out of the tranny and as far as the starting problem have u checked ur battery? can u jump it off with another car? could be starter, battery, altanator, fuse?? maybe
Old Dec 4, 2007 | 02:06 PM
themex77's Avatar
Default Re: cel code 17 VSS - speed sensor!!!!!! need help (crxfreak1117)
yha my speedo works so no sure there yha i tried jumpin it wit another car and still no go so im thinkin the battery but still shouldnt the car crank if there is even a little bit of charge in the battery?
thanks
Old Dec 4, 2007 | 02:12 PM
thegooddoctorceretti's Avatar
this just happened on my 91 crx si, check and see if your battery terminals are coroded or if they have lost contact with the battery another way. pot off both posi and negative and give them a good wire brush cleaning with some baking soda. thats all mine was and it sounds like the same problem
Old Dec 4, 2007 | 02:30 PM
themex77's Avatar
Default Re: cel code 17 VSS - speed sensor!!!!!! need help (thegooddoctorceretti)
hey thanks apreccitate it ill try it and see what happens thanks
Old Dec 4, 2007 | 06:05 PM
check the clutch switch
Old Dec 7, 2007 | 01:16 PM
themex77's Avatar
hey im bak i tried cleaning the posts no luck i bypassed the switch and still same thing i mean the only thing left is the starter right ??? battery is good i tryed another battery so not that not sure what it could be its weired like if i push da car for a couple feet then try 2 crank it again turns on fine so that has me puzzled not sure what it could be i was thinking of taking of my starter and taking it 2 autozone for some testing no sure tho what you guys think??
thanks
gwegcivic
Dec 11, 2008 08:59 PM
EF9 JAMS!!!
Dec 10, 2006 10:26 AM
DC2 Mang
May 9, 2005 08:55 AM
Mefain
May 2, 2005 06:29 PM
FrankencrxBHAM
Oct 27, 2004 02:45 PM
