fresh JDM B20b swap Running but a few problems!
Old Dec 4, 2007 | 11:10 AM
Honda_Fanatic's Avatar
Default fresh JDM B20b swap Running but a few problems!
Starts and idles, but when I try and hit the gas to rev it up sometimes it bogs and wants to die, or it revs very slowly!
Obviously its not drivable, but what could be causing this?
I am sure I am missing something real simple!
Old Dec 28, 2007 | 03:29 PM
Bac91Da's Avatar
Default Re: fresh JDM B20b swap Running but a few problems! (Honda_Fanatic)
U Should check the timing on it that will make it bog, is it when you hit the gas real fast or can you slowly rev it alil and it not be as bad?
Old Dec 28, 2007 | 08:16 PM
Default Re: fresh JDM B20b swap Running but a few problems! (Bac91Da)
It was incorrect injectors (OBD1 when I needed OBD0) cause I am using the resistor box.
All fixed - Thanks
detour94civic
Dec 27, 2010 01:35 PM
92integracer
Oct 7, 2008 07:05 PM
89 crix si
100
Dec 30, 2007 10:33 AM
RexedM3
11
Jun 27, 2004 09:08 PM
KevronsEG
Mar 30, 2003 06:10 AM
