charcoal canister?
Old Dec 4, 2007 | 11:00 AM
dc2_dude's Avatar
Default charcoal canister?
i have a 99 gsr, my charcoal canister has a hole in it b/c it rubbed against my axle. Should i replace it or will it hurt to run my car without it? please let me know asap. thanks
Old Dec 4, 2007 | 04:00 PM
96civictyper's Avatar
Default Re: charcoal canister? (dc2_dude)
i dont think it will hurt anything, u just may smell fuel
Old Dec 4, 2007 | 04:21 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
im running my car without that, but dam it smells, but whatever
Old Dec 13, 2007 | 10:19 AM
dc2_dude's Avatar
well it seems to run fine, no more coolant leaks or any thing, it does smell like raw *** though when i start it in the garage and its freezing and it idles low as hell until it warms up. here's a pic of the bay
Old Dec 13, 2007 | 10:57 AM
Default Re: (dc2_dude)
hey hows your gas mileage,mine seemed to be bad after i took out canister? anyone no if this is true?
Old Dec 13, 2007 | 11:01 AM
AWD Terror's Avatar
Default Re: (DOHCgarage919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">hey hows your gas mileage,mine seemed to be bad after i took out canister? anyone no if this is true?</TD></TR></TABLE>
Makes sense
Old Dec 13, 2007 | 11:08 AM
Default Re: (AWD Terror)
how does taking canister out affect your gas mileage??thanks and if it does how much does it affect ur gas milage, cuz if its a lot, its going back in
Old Dec 13, 2007 | 11:12 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">how does taking canister out affect your gas mileage??thanks and if it does how much does it affect ur gas milage, cuz if its a lot, its going back in</TD></TR></TABLE>
It is directly linked to your fuel system. That's why I was saying it makes sense.
Not sure if it does hurt your mileage or not, but it makes sense.
A buddy has ran his boosted LS for 1,000+ miles with out a canister, so I don't see it causing any problems.
Old Dec 13, 2007 | 11:17 AM
dc2_dude's Avatar
i havnt noticed it really, but then again i dont drive this car everyday anymore, its winter and cold in ohio so it sits in the garage unless i dont feel like driving the supra
Old Dec 13, 2007 | 11:27 AM
integra4eva's Avatar
nice and clean thats way i like 'em!!!!!!!!!!!!
Old Dec 13, 2007 | 11:29 AM
AWD Terror's Avatar
Default Re: (integra4eva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra4eva &raquo;</TD></TR><TR><TD CLASS="quote">nice and clean thats way i like 'em!!!!!!!!!!!! </TD></TR></TABLE>
Get back to A/C
Old Dec 13, 2007 | 01:16 PM
dc2_dude's Avatar
ok the only problem i ran into with swapping my manifold and deleted the evap canister was this. one of these lines somehow was ran to my canister and made it fill up with coolant and rubb on my axle and now there's a hole in it. the green circled runs to my block the purple circled ran to my canister, but now it just capped off, where is this supposed to go please help
Old Dec 14, 2007 | 12:59 PM
GSR-TRBO-DA's Avatar
dude your gas is just evaporating into the air. hello it is not called an evap for nothing.
Old Dec 14, 2007 | 01:03 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I would put the canister back on (another one without a hole of course), but figure out why it's rubbing against the axle. Did you not have it properly secured in the bracket on the frame rail?
Old Dec 14, 2007 | 02:24 PM
Default Re: (PatrickGSR94)
ya ima put mine back on too, it smells bad, and my gas milage is horrible,was never this bad it has to be the canister
Old Jan 25, 2008 | 06:23 PM
redDAinteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">ya ima put mine back on too, it smells bad, and my gas milage is horrible,was never this bad it has to be the canister </TD></TR></TABLE>
Did you put the canister back in ? And if so did your gas mileage change ?
Old Jan 29, 2008 | 06:29 PM
Default Re: (redDAinteg)
no didnt put it back in , i guess my mpg is ok so , not going in
Old Jan 29, 2008 | 07:19 PM
SOHC_4dr's Avatar
well just hope you dont have to get e-checked. lol you need to have that put on. it stores vapor from the tank and uses them when your at crusing speeds. your mileage will be a lot better.
Old May 30, 2008 | 11:40 AM
wastedyouth2542's Avatar
Default Re: charcoal canister? (DOHCgarage919)
do you just pull it out or what, what hoses do you plug and what do you do with the other one?
Old May 30, 2008 | 12:04 PM
dthug's Avatar
Default Re: charcoal canister? (wastedyouth2542)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_4dr &raquo;</TD></TR><TR><TD CLASS="quote">well just hope you dont have to get e-checked. lol you need to have that put on. it stores vapor from the tank and uses them when your at crusing speeds. your mileage will be a lot better.</TD></TR></TABLE>
this is correct.
Old Mar 21, 2010 | 08:30 PM
Judg3ment98's Avatar
my civic is having a problem with the charcoal canister as well. It filled with coolant and im not sure why. If anyone has any suggestions, they would be greatly appreciated.
DjBij099
Mar 23, 2008 12:59 AM
vervuurt
Jan 3, 2008 08:20 AM
aaronISthrowed
Mar 19, 2007 06:13 AM
The Destroyer
Nov 9, 2005 12:34 PM
Lost Type R
Aug 25, 2003 10:33 PM
