JDM B18C TYPE R FULL SWAP!!, Fully built, 13.5 TO 1 COMPRESSION, 2K ON THE MOTOR!!!
Old Dec 4, 2007 | 09:51 AM
LSVTEC426's Avatar
Default JDM B18C TYPE R FULL SWAP!!, Fully built, 13.5 TO 1 COMPRESSION, 2K ON THE MOTOR!!!
Recently the EK hatch was wrecked and in the process of getting an evo. Need this all gone. You can buy from me, or buy from HMO and get the exact same thing except stock for the same price. Taking 5k for the whole thing
JDM B18C Type R motor
-13.5 to 1 compression
-Fresh build (Motor was only in car for 2k miles) then car was wrecked on drivers side.
-Wiseco Pistons
-Eagle H beam rods
-Crane stage 1 cams
-LSD Hydraulic Tranny (S80) no grinds at all. MINT tranny
- ECU (P73)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
Need to be clear on this, NOTHING WILL BE PARTED OUT SO PLEASE DONT ASK
ALSO HAVE TONS OF OTHER **** FROM THE CAR
JIC MAGIC FULL SUSPENSION
SI CLUSTER
5 LUG CONVERSION
BLACK ROTA SLIPSTREAMS WITH NEW TIRES.
DEL SOL SEATS
TONS AND TONS OF OTHER ****, PLEASE JUST ASK. EVERYTHING ON THE CAR MUST GO!!!!
Call anytime, 724 953 4309
Old Dec 4, 2007 | 08:22 PM
LSVTEC426's Avatar
Default Re: JDM B18C TYPE R FULL SWAP!!, Fully built, 13.5 TO 1 COMPRESSION, 2K ON THE MOTOR!!! (LSVTEC426)
ttt
Old Dec 5, 2007 | 10:24 AM
LSVTEC426's Avatar
bump
Old Dec 9, 2007 | 07:14 PM
taeim's Avatar
What year and the original miles ?
Old Dec 17, 2007 | 07:58 PM
LSVTEC426's Avatar
Default Re: JDM B18C TYPE R FULL SWAP!!, Fully built, 13.5 TO 1 COMPRESSION, 2K ON THE MOTOR!!! (taeim)
just give me a call and ill go over the details
Old Jan 25, 2008 | 12:43 AM
EG6_11's Avatar
still have the motor?
Old Jan 25, 2008 | 01:21 AM
Civic DX 4dr's Avatar
Default Re: JDM B18C TYPE R FULL SWAP!!, Fully built, 13.5 TO 1 COMPRESSION, 2K ON THE MOTOR!!! (EG6_11)
pm'd
Old Feb 5, 2008 | 09:35 AM
LSVTEC426's Avatar
BUMP
Burrows_M
24
May 13, 2009 10:25 AM
endokun83
Mar 16, 2007 10:03 PM
HAHAV8
Oct 11, 2005 09:17 AM
joe_black
Aug 5, 2005 09:39 AM
