Need some teg brake rotor dimensions
Old Dec 4, 2007 | 07:34 AM
Jared's Avatar
Default Need some teg brake rotor dimensions
Looking for two front rotor measurements, one: depth from inside hub area to inside edge of rotor surface, two: inside diameter of hub opening i.e. how big of a hub would fit?
Old Dec 4, 2007 | 09:41 AM
Trakhor's Avatar
Torque Junkie
Default Re: Need some teg brake rotor dimensions (Jared)
Which year teg rotors?
Are you trying to do a big brake swap? If so there is plenty of that info in the faq.
Old Dec 4, 2007 | 11:32 AM
CRX Toad's Avatar
https://honda-tech.com/zerothread/1811368
https://honda-tech.com/zerothread/1508680
You also know Integra don't all run the same size rotor be specific
Old Dec 4, 2007 | 02:14 PM
Jared's Avatar
I did not know they didn't all run the same size fronts, I thought 90+teg exc ITR, anyway, I'm looking specifically for 90-93 which is what i think fits an sir knuckle. Thanks for the links, I'll dig through them, I hope they have what I need.
Modified by Jared at 6:35 PM 12/4/2007
Jared's Avatar
Default Re: Need some teg brake rotor dimensions (Trakhor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trakhor &raquo;</TD></TR><TR><TD CLASS="quote">Which year teg rotors?
Are you trying to do a big brake swap? If so there is plenty of that info in the faq.</TD></TR></TABLE>
not doing a brake swap, need measurements for a project.
Sinner
Dec 29, 2005 09:20 AM
99civic_exSB
Jun 2, 2003 11:52 AM
HatchBox
May 16, 2003 11:52 AM
NegativeLift
Honda Motorcycles
Feb 3, 2003 11:50 AM
Doctor CorteZ
Oct 19, 2002 11:32 PM
