can a shift light be wired into the ecu?
Old Jun 26, 2002 | 08:30 AM
Aaron M's Avatar
Default can a shift light be wired into the ecu?
i know theres a rpm wire on the ecu, can i wire a shift light into that wire, im sure it would give me a more accurate reading am i right?
Old Jun 26, 2002 | 08:59 AM
StyleTEG's Avatar
Default Re: can a shift light be wired into the ecu? (SilverB18C1)
Yup, it can. Apex'i S-AFC and V-AFC tap into that wire.
I almost did it myself, but got nervous about tapping into ECU wires and used the one on the gauge bezel plug.
Old Jun 26, 2002 | 10:44 AM
Aaron M's Avatar
Default Re: can a shift light be wired into the ecu? (StyleTEG)
im using the one on the cluster right no, but its 100rpms off, i would like to tap into the ecu for a more accurate reading, hopefully.
Old Jun 26, 2002 | 12:40 PM
Cramerox's Avatar
most people tap into the distributor....but what ever works.
Old Jun 26, 2002 | 01:05 PM
Aaron M's Avatar
Default Re: can a shift light be wired into the ecu? (Cramerox)
im trying not to have any wires running outta the bay, just makes me feel better knowing everything is contained.
so does anyone know what wire it is? color? pin#?
Old Jun 26, 2002 | 01:59 PM
StyleTEG's Avatar
Check Apex'i website and look for the diring diagrams for the AFC controllers.
Old Jun 26, 2002 | 02:27 PM
Aaron M's Avatar
the didnt have odbII ecu diagrams
Old Jun 26, 2002 | 02:31 PM
StyleTEG's Avatar
Really? Thats pretty strange... because they do have ODB II ecu diagrams
http://www.apexi-usa.com/productdocu...afc_update.pdf
Old Jun 26, 2002 | 02:33 PM
Aaron M's Avatar
heh silly me, i was looking under safc, THANKS, i woudl use WH-3 right? for a 2001 gsr
Old Jun 26, 2002 | 06:55 PM
Aaron M's Avatar
OK i did it! the RPM signal wire on a ODBII ECU is the yellow wire with a green stripe on it and silver markings. you can find this wire on the center(middle) connector of the 3
Old Jun 30, 2002 | 01:08 PM
speedymon's Avatar
Do you have a monster tach or just a shift light. I don't want a monster tach.
Old Jun 30, 2002 | 01:27 PM
Aaron M's Avatar
Default Re: can a shift light be wired into the ecu? (speedymon)
just the shift light, but either of the 2 can be wired into that rpm signal wire
Old Jul 1, 2002 | 07:24 AM
speedymon's Avatar
Don't you have to have the trigger box that tell the light when to turn on at a certain rpm
Old Jul 1, 2002 | 09:30 AM
Maximo's Avatar
my hondata shift light is wire to my check engine light which comes on at 8200 rpm
Old Jul 1, 2002 | 10:00 AM
Cramerox's Avatar
Default Re: can a shift light be wired into the ecu? (NXTEG)
Old Jul 1, 2002 | 10:28 AM
Austin's Avatar
To each their own...it's been working for me...I have 2 shift lights, I use the Hondata for first gear due to reaction times, and I use my normal shift light for 2nd gear and up...
b18b1ef8
Apr 18, 2008 10:20 AM
yellowjdmcrx
17
Nov 21, 2005 02:57 AM
Sketch_hs
Aug 19, 2004 08:44 AM
b20_ed
Jul 14, 2003 10:34 AM
CimorelliCRX
Sep 21, 2002 02:20 PM
