b17 with p72 ecu obd1, will it pass smog?
Old Dec 3, 2007 | 09:06 PM
sPaRk'iT's Avatar
Default b17 with p72 ecu obd1, will it pass smog?
^^^^As topic stated...
Old Dec 3, 2007 | 09:45 PM
LordAphotic's Avatar
a b17 is way more similar to a b16 than it is to a G3 GSR.
more than likely its going to be running too rich and also the stroke is different so it might run too hot or too cold cause of the electronic timming controlled by the ecu....
the fuel tables and the ignition tables are different....
ask them to run it off the computer system so u can get the results first then if the results are good then do the real test.
Old Dec 4, 2007 | 08:47 PM
sPaRk'iT's Avatar
Default Re: (LordAphotic)
how about a p28?
Old Dec 6, 2007 | 07:31 AM
Tomdata's Avatar
Default Re: (sPaRk'iT)
As long as you have a good catalytic converter, a good 02 sensor, the check engine light is not on and the timing is set to 16* you should be fine.
civicboy1128
Jul 26, 2011 09:50 PM
'00DC2
Northern California
Oct 19, 2010 06:42 PM
nikitad
Northern California (Sales)
Sep 29, 2008 07:31 PM
egg_baLLa
Mar 11, 2008 07:44 AM
b00sted4dr
Feb 7, 2008 09:17 AM
