Stainless or Aluminum
Old Dec 3, 2007 | 07:03 PM
riceburner6's Avatar
Default Stainless or Aluminum
Hey guys...im going to be throwing a custom exshaust on my hatch...stainless or aluminum for my choice? i was thinking 2.5''? hows it sound.
Casey
Old Dec 3, 2007 | 08:24 PM
DESTROYER's Avatar
Sounds good!
Old Dec 3, 2007 | 09:41 PM
k24em2's Avatar
Default Re: Stainless or Aluminum (riceburner6)
Sounds honda good!
Old Dec 3, 2007 | 09:50 PM
johnls's Avatar
Default Re: Stainless or Aluminum (k24em2)
well if you are burning rice you will want to use stainless less work on clean up j/k just buy one made for your car will be better and less time i would go with a virbant muffler if you do make you own sounds good
Old Dec 5, 2007 | 06:56 AM
should i go all aluminum or go like half stainless then to aluminum. cause im going to run dual?!
Old Dec 5, 2007 | 09:31 AM
k24em2's Avatar
Default Re: (riceburner6)
make half of the pipe aluminum and half of the pipe stainless and weld it all together like this:
stainless --->()<---aluminum
Old Dec 5, 2007 | 09:59 AM
Andy R's Avatar
Default Re: (k24em2)
and for safety sake you should put a rubber coupler around it
Old Dec 5, 2007 | 12:18 PM
m R g S r's Avatar
2.5" will not provide enough back pressure for you.
go with 1.5" sch 10 or 40 it will be rock solid
Old Dec 5, 2007 | 02:56 PM
????i dunno dude, im thinking 2.5...
Old Dec 5, 2007 | 03:15 PM
m R g S r's Avatar
naaa..be like midwestautoworks....he wanted to use sch40 for his exhaust..**** was gunna be rock solid
Old Dec 5, 2007 | 03:20 PM
vtecspeed1320's Avatar
Shooting Star
im thinking the 1.5" sch 10 or maybe 1.5" 16ga, backpresure will be spot on and the a/f ratio will be perfect.
Old Dec 6, 2007 | 09:54 AM
so 1.5 on the dual? then just fab. with the tips on them?
im adding a O-Pipe as well...
Old Dec 6, 2007 | 10:27 AM
k24em2's Avatar
Don't forget to add a Q pipe, they are usually good for about 25hp
Old Dec 6, 2007 | 11:26 AM
GTibunny16v's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner6 &raquo;</TD></TR><TR><TD CLASS="quote">so 1.5 on the dual? then just fab. with the tips on them?
im adding a O-Pipe as well...</TD></TR></TABLE>
Yeah, do dual 1.5" pipes, you know how your exhaust downpipe has 2 pipes that go to 1. Just cut it so you can have dual pipes all the way back into 2 mufflers. **** will sound ******* hot. Plus youll have like 40 more hp if you do it that way.
Old Dec 6, 2007 | 12:26 PM
hybrid2007's Avatar
Default Re: (GTibunny16v)
I think you should go with the half Alu, half stainless zorst. You've got the light weight Alu and the bling bling stainless all in one.
Make sure you use dissimilar wire though!
Old Dec 6, 2007 | 01:14 PM
XLR8 GS-R's Avatar
Default Re: (hybrid2007)
do u mean aluminized steel? I hope so.. lol funny posts
Old Dec 6, 2007 | 01:19 PM
HiProfile's Avatar
The only reason you want dual exhaust is to win a rice show, or if you seriously have space restrctions. For NA, you don't need anything beyond 2.25", let alone dual 2.5". A 2" pipe is more than enough for a modified 1.8L Honda motor. You need to maintain some backpressure with an NA motor, especially if it has lots of lift/overlap like a DOHC VTEC motor has. Otherwise through most of the RPM range you'll end up with fresh intake air + fuel flowing right through the cylinder into the exhaust. That air could have been used for a handful of whp, meaning excessive NA exhaust size isn't always best.
Turbo cars need larger exhausts because the turbo & manifold create more than enough backpressure than is needed, and the lower you can get the pressure in a turbo vehicle's post-turbo exhaust, the better.
Old Dec 6, 2007 | 02:54 PM
so....full dual correct 1.5'' back to 2 mufflers. what kind of material should i use? i was thinkin all aluminum. what should i do?
also how do you install a O-pipe or w.e its calles?
casey
Old Dec 6, 2007 | 04:36 PM
k24em2's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">The only reason you want dual exhaust is to win a rice show, or if you seriously have space restrctions. For NA, you don't need anything beyond 2.25", let alone dual 2.5". A 2" pipe is more than enough for a modified 1.8L Honda motor. You need to maintain some backpressure with an NA motor, especially if it has lots of lift/overlap like a DOHC VTEC motor has. Otherwise through most of the RPM range you'll end up with fresh intake air + fuel flowing right through the cylinder into the exhaust. That air could have been used for a handful of whp, meaning excessive NA exhaust size isn't always best.
Turbo cars need larger exhausts because the turbo & manifold create more than enough backpressure than is needed, and the lower you can get the pressure in a turbo vehicle's post-turbo exhaust, the better.</TD></TR></TABLE>
heh, backpressure=bad in all cases
k24em2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner6 &raquo;</TD></TR><TR><TD CLASS="quote">so....full dual correct 1.5'' back to 2 mufflers. what kind of material should i use? i was thinkin all aluminum. what should i do?
casey</TD></TR></TABLE>
You can use sch 10 pvc
Old Dec 7, 2007 | 06:04 AM
Forget the O pipe, you dont need it on duals. Do a titanium muffler with the flame tip and aluminum piping for the rest, **** will be the cats meow.
Old Dec 7, 2007 | 10:01 AM
ok dual aluminum piping. back to the tips.
what does the o-pipe do? and how would i install it if i did get it?
Old Dec 7, 2007 | 10:04 AM
k24em2's Avatar
It gives it a throaty sound like a supra
Old Dec 7, 2007 | 10:26 AM
dbiker207's Avatar
you need to get this. read the reviews
http://kalecoauto.com/index.ph..._id=2
the_unknown's Avatar
GDD Lonely Krew
+1 for motec system exhaust.....
