OBD1 LS in a OBD2 Ek coupe, o2 sensor help
Old Dec 3, 2007 | 06:52 PM
Ryan97's Avatar
Default OBD1 LS in a OBD2 Ek coupe, o2 sensor help
I just swapped an LS(94) in my EK, my friend wired it up to be obd2(running an obd2 ecu) so the ecu is looking for 2 o2 sensors and my motor only has one(but my wiring harness has room for 2) is it hard to put an o2 sensor on the header? i tried searching and came up with nothing,
Old Dec 3, 2007 | 07:06 PM
ltrkstr2k's Avatar
Default Re: OBD1 LS in a OBD2 Ek coupe, o2 sensor help (Ryan97)
just get a obd2 cat and use the 2nd o2 sensor from the coupe and plug it back in under the car. or you can get a bung that needs to be welded into the exhaust and put the sensor in there.
Old Dec 3, 2007 | 08:06 PM
Ryan97's Avatar
Default Re: OBD1 LS in a OBD2 Ek coupe, o2 sensor help (ltrkstr2k)
too bad the exhaust place that did my exhaust took my Cat...*******. now i gotta weld a bracket to bolt up to the triangle part of the cat
Old Dec 3, 2007 | 08:08 PM
ariza034's Avatar
why not keep it obd1
Old Dec 3, 2007 | 08:12 PM
Ryan97's Avatar
Default Re: OBD1 LS in a OBD2 Ek coupe, o2 sensor help (ariza034)
what do u mean? 4 the cat??? i would, both obd1 and 2 have o2 sensors i think
Old Dec 3, 2007 | 08:19 PM
ltrkstr2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ariza034 &raquo;</TD></TR><TR><TD CLASS="quote">why not keep it obd1</TD></TR></TABLE>
yeah just convert to obd1 and you only need the 1st o2 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan97 &raquo;</TD></TR><TR><TD CLASS="quote">what do u mean? 4 the cat??? i would, both obd1 and 2 have o2 sensors i think
they both have o2 sensors the difference is that obd1 only has 1 and obd2 has well 2
Old Dec 3, 2007 | 08:24 PM
Ryan97's Avatar
i knew obd2 has 2 o2 sensors but why not just buy a cheap *** cat and have the 2nd o2 hooked up, i need to get my car running right(idles really bad) it may be from the o2 sensor being close to the exhaust(straight header) so its running rich or idk but i gotta get **** goin, just ordered a cat, thanks 4 ur help guys
Old Dec 3, 2007 | 08:44 PM
ltrkstr2k's Avatar
724chris
Jan 23, 2010 07:04 PM
stiffinEK
May 3, 2009 12:40 PM
SlammedBlackGSR
Oct 14, 2006 06:57 PM
elmalouno
Jul 18, 2004 08:55 PM
Del_Slowest
Oct 25, 2003 01:22 PM
