92 Dx, New dizzy,no spark, no fuel pump, no pulses, Help
Old Dec 3, 2007 | 05:55 PM
tfalconier's Avatar
Default 92 Dx, New dizzy,no spark, no fuel pump, no pulses, Help
Hey guys, im workin on a 92 dx, the car doesnt run, And when i got the car it had no spark, so i put a brand new dizzy in it, and still nothing, then i noticed the fuel pump isnt going, and i am not getting any injector pulses, could i have a bad computer? The cars wiring seems fine, i heard somewhere on here that if the computer isnt getting a reading the check engine light will always stay on durning cranking but im not sure about that? What else could i be missing.. i also checked every fuse in the car thinking maybe it was something simple, but nope..
Old Dec 19, 2007 | 05:54 PM
tfalconier's Avatar
Default Re: 92 Dx, New dizzy,no spark, no fuel pump, no pulses, Help (tfalconier)
anything guys? ive seen similar topics about this but nobody has fixed them yet
Old Dec 19, 2007 | 05:58 PM
wicked_b16eg's Avatar
Sound like a ECU problem. Try finding a friend with any 92-95 non v-tec and try theres. If it starts you found your problem
Old Dec 19, 2007 | 07:27 PM
JBrettHowell's Avatar
Bad relay?
Old Dec 19, 2007 | 07:28 PM
tfalconier's Avatar
Default Re: 92 Dx, New dizzy,no spark, no fuel pump, no pulses, Help (JBrettHowell)
yup i forgot to put that in the original post, the relay is good
Old Dec 19, 2007 | 07:30 PM
tfalconier's Avatar
i have a 93 ex, could i put the po6 computer in my car just to see if it runs even tho i have a p28? i dont want to try my p28 in the dx incase it fries it
z6hatchboy's Avatar
If your cel has stayed on, have you tryd checking it? Sound like a ground issues, or relay
Old Dec 19, 2007 | 07:36 PM
1992cxcivicEG's Avatar
Default Re: (z6hatchboy)
hey you might want to make sure your ground is going strait to the unibody from the battery... that is what it sounds like to me...
Old Dec 19, 2007 | 07:48 PM
tfalconier's Avatar
Default Re: (1992cxcivicEG)
the grounds are good, i checked all the simple stuff, i just bought a p06 so im gonna try that when it comes, i know some people have gotten bad dizzyz but i have no injector pulses, and no fuel pump, i saw similar threads on here before about this but i hope my ecu will be the trick
Old Dec 20, 2007 | 08:03 PM
tfalconier's Avatar
Default Re: (tfalconier)
i got the factory honda manual and i tried everything in it, anybody know what else it could be?
Old Dec 20, 2007 | 10:04 PM
speedooo's Avatar
if you put the key in the second position and the cel does not turn off the car will not start. change the ecu
jorge_131
Feb 25, 2019 06:04 PM
johndellago
Jul 22, 2013 01:40 AM
Kris's turbo
May 8, 2013 12:50 PM
5thGenFanatic
Nov 26, 2007 08:19 AM
EGfosho
Jun 14, 2007 03:57 PM
