help with coolant problem...
Old Dec 3, 2007 | 05:18 PM
resurectedvikin's Avatar
Default help with coolant problem...
ok so i just dropped a stock d16z6 into my eg si (replacement motor). and it all starts up fine and everything, but my oem temperature gauge doesn't work, and i think its over heating.
the top rad hose gets really hot, the bottom one only gets warm. quite a bit cooler than the top one, but not completely cool.
could this mean my water pump is shot?
motor burns no oil or coolant. and i just replaced the thermostat....
A) why could the temp gauge not work?
B) why is the bottom pipe cooler than the top?
i checked the factor coolant temp sensor for resistance, its consistant with what it should be....
Old Dec 3, 2007 | 06:00 PM
Default Re: help with coolant problem... (resurectedvikin)
i also have to add, that it always runs in cold mode, aka hard on fuel, running super rich, NO vtec engaging.....i tried a different ecu..didn't help the issue..
Old Dec 4, 2007 | 06:45 AM
buzzzump that shizz. need some help people..
Old Dec 5, 2007 | 09:34 AM
bump. you guys suck lol
Old Dec 5, 2007 | 11:28 AM
pimpinblackcivic's Avatar
either the thermostat is faulty or your coolant temp sensor plug is out or the sensor faulty.
if its not engaging vtec and running cold i'd go with the second
Old Dec 5, 2007 | 11:38 AM
p nut's Avatar
May I ask how you know that the car is overheating?
Old Dec 10, 2007 | 12:13 PM
Default Re: (p nut)
well there is no coolant being circualted and the top pipe gets hotter than i can handle to touch....notice how i said i THINK its over heating. i'm going to try to replace the coolant temp sensor...its just weird that the gauge and the ecu and the fan coolant sensors would all go at the same time.
almost immediately after the car is started the cooling fan comes on...
Old Dec 10, 2007 | 12:17 PM
as with my post above check the thermostat isnt stuck shut
obuhmyuh
Mar 7, 2010 01:27 PM
elmejor
Apr 5, 2009 09:17 AM
aasaa666
Apr 26, 2005 07:43 AM
0bd1_Kanobe
14
Jun 4, 2004 04:09 PM
planeman01
Oct 28, 2002 03:22 PM
