dx to si cluster
Old Dec 3, 2007 | 03:41 PM
Mr.Meowsome's Avatar
Default dx to si cluster
i have an 89 dx and i'm trying to put an si cluster in. i think its also an 88-89 cluster. i've searched this site, the FAQ here, google and d-series.org for a diagram but came up with nothing. throw me friggn bone
Old Dec 3, 2007 | 06:14 PM
black0hatch's Avatar
Default Re: dx to si cluster (Mr.Meowsome)
diagram for what? you just plug it in.
Old Dec 3, 2007 | 06:17 PM
Fuzzy Rhubarb's Avatar
Default Re: dx to si cluster (black0hatch)
Not really sure what you want to know, but this page helps you figure out the differences between a 90 and 89.
http://www.ef-honda.com/ben/sicluster.php
Old Dec 3, 2007 | 08:02 PM
Default Re: dx to si cluster (Fuzzy Rhubarb)
well that did help alittle. i did not know that they were a plug and play provided the years are the same. when i first got it i tried it out and the CEL stayed on but i didnt drive around. thats why i thought that wires had to be switched
Old Dec 3, 2007 | 08:04 PM
your old cluster works fine though right?
Old Dec 4, 2007 | 05:11 AM
right. the tach in the new one didnt work either
Old Dec 4, 2007 | 05:51 AM
gourley's Avatar
I just did a STD cluster to a sI cluster and all I did was unplug and replug in my cluster making sure the speedo cable was plugged in correctly. Unless your wiring is messedup then it should be a 100% plug and play if your going from a 88-89 cluster to a 88-89 cluster. A 90-91 cluster will not work.
Old Dec 4, 2007 | 07:27 AM
Default Re: dx to si cluster (gourley)
its definatley an 88-89. the seat belt light is on the top middle, between the turn signals. its also the same shape as my current cluster. it fits right in. i hate wires
Old Dec 4, 2007 | 10:08 AM
i just tried it out again and when i start it up the CEL and the seatbelt lights stay on and the tach works but it doesnt read the right rpms. when its idling it sits at 6500, and when i popped the hatch the lights got brighter, and the fuel gauge and tach stopped working
Old Dec 4, 2007 | 02:27 PM
could there be something wrong with the cluster?
Old Dec 4, 2007 | 02:32 PM
gourley's Avatar
plug your dx cluster in agian and see if it works with no CEL's and the seatbelt light turns off. If that works then you have a broken cluster
Old Dec 4, 2007 | 02:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Meowsome &raquo;</TD></TR><TR><TD CLASS="quote">could there be something wrong with the cluster?</TD></TR></TABLE>
If you have the correct cluster, it could be. Check the traces on the back for shorts, corrosion, etc. Plus, are you ABSOLUTELY SURE that the cluster is an 89 SI cluster or 88-89 CRX cluster?? If not, then everything will work really weird/not at all/explode.
Old Dec 4, 2007 | 05:23 PM
im not sure if its from a civic or crx. i didnt even know there is a difference
hondanator88
18
Oct 30, 2010 04:10 PM
civicb16eg
Jun 26, 2008 07:37 AM
shotty
Mar 30, 2003 02:59 PM
Speedfreak
Dec 11, 2002 04:43 PM
exr_pd
May 22, 2002 12:03 PM
