Question about a blocked cat...
Old Dec 3, 2007 | 02:18 PM
slacks's Avatar
Default Question about a blocked cat...
Would it make a difference in power if my engine was revving as opposed to in gear with a blocked cat?
I think my car is blocked as it was cause back pressure through the gasket, but the engine revs higher than is does when in gear.
Is this still a cat problem or more of a tranny problem?
Old Dec 3, 2007 | 02:50 PM
slacks's Avatar
Default Re: Question about a blocked cat... (slacks)
bump?
Old Dec 3, 2007 | 03:17 PM
posHonda's Avatar
By blocked do you mean clogged? And revving in gear meaning while the clutch is engaged? Specify a bit more please...
Your car should rev just like in neutral if your clutch is engaged.
Old Dec 3, 2007 | 03:22 PM
slacks's Avatar
Default Re: (posHonda)
let's break this down.
While driving with a presumed blocked/clogged cat....my car had no power and would not rev at all.
When the daylight came out i noticed there was a surge of air coming from the cat's gasket, but could still rev higher.
is this still a cat problem or a tranny problem? (both have been slowly going on me)
Old Dec 3, 2007 | 03:25 PM
posHonda's Avatar
Replace the cat first. Since its in neutral it doesnt have to spin the tranny/wheels so it takes much less effort to get the motor going.
Old Dec 3, 2007 | 03:34 PM
slacks's Avatar
that's what i was hoping for
the new test pipe is coming soon so i'll replace it and see then
thanks
DB1_559
Apr 30, 2009 10:45 PM
NA JDM GSR
May 24, 2006 07:52 AM
kupras
Oct 18, 2004 02:39 PM
randomwalk101
Nov 7, 2001 12:36 PM
