mini me wont start need help.
Old Dec 3, 2007 | 01:55 PM
waynecoSI's Avatar
Default mini me wont start need help.
i did the mini me swap for a guy and everything is together, engine cranks, plug wires are getting spark, but it wont start.By the timing marks on the cam gear and the notch on the crank, it should be in time. It cranks just fine. I took the plugs out and they are wet from fuel. this is in a 92'. ANY help would be appreciated.
Modified by waynecoSI at 4:46 PM 12/3/2007
Old Dec 3, 2007 | 03:17 PM
waynecoSI's Avatar
Default Re: mini me wont start need help. (waynecoSI)
anyone???
Old Dec 3, 2007 | 04:33 PM
ekquebec's Avatar
check the compression, I had the same problem and my valve was not adjusting find.
Old Dec 4, 2007 | 06:01 PM
waynecoSI's Avatar
Default Re: mini me wont start need help. (ekquebec)
had to advance the timing 4 teeth and the ICM gave out on the dizzy. swaped that out and started right up and sounded great.
Da9austinRacing
Feb 8, 2011 06:35 PM
lt1guy
Feb 14, 2010 07:06 PM
gsrboost737
Apr 16, 2009 11:38 PM
vtecsi00
10
Feb 25, 2008 06:44 PM
