car sounding like a Subie Idle Rumble
Old Dec 3, 2007 | 12:24 PM
d0ugch0i's Avatar
Default car sounding like a Subie Rumble
my car is acting up and idles really low at 1rpm and lower. whenever i accelerate the car sounds like a Subie and doesnt seem to pulling its full potential. it seems really weak when i gas the car. the engine shakes too when i looked at it. any help??
Old Dec 3, 2007 | 12:26 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: car sounding like a Subie Rumble (d0ugch0i)
cylinder misfire?
do you have a CEL?
Old Dec 3, 2007 | 12:40 PM
St Jimmy's Avatar
* B A N N E D *
Yea it sounds like your running on 3 cylinders, check your spark plugs and wires and make sure one didnt pop loose. Maybe a clogged injector?
Old Dec 3, 2007 | 01:09 PM
TrustAutoPerformance's Avatar
Its a misfire. Wash down your engine bay lately? You might have gotten water into one of your spark plug holes. Could also be an ignition or fuel problem as stated above.
Old Dec 3, 2007 | 07:15 PM
d0ugch0i's Avatar
yea i just recently washed my engine bay. ill check up on the spark plugs and the injectors first thing tommorow morning.
Old Dec 3, 2007 | 07:53 PM
nipcup101's Avatar
Default Re: (d0ugch0i)
yup this happen to me and it was my injector wasnt pluged in all the way lol make sure all clips are pushed down
Old Dec 3, 2007 | 08:53 PM
clean3two3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d0ugch0i &raquo;</TD></TR><TR><TD CLASS="quote">yea i just recently washed my engine bay. ill check up on the spark plugs and the injectors first thing tommorow morning.</TD></TR></TABLE>
i would never wash my engine i would rather do it by hand instead of washing it
Old Dec 3, 2007 | 10:39 PM
VTEC_PRODUCTION's Avatar
Default Re: (clean3two3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean3two3 &raquo;</TD></TR><TR><TD CLASS="quote">
i would never wash my engine i would rather do it by hand instead of washing it</TD></TR></TABLE>
ive power washed my share of engines and just make sure you look over everything before you start...its not that big of deal. ive seen alot of **** the mechanics and people do that just amaze me...there really isnt much hurt in power washing the bay.
Old Dec 4, 2007 | 11:45 AM
d0ugch0i's Avatar
got it fixed. it turned out to be 2 spark plug wires that were messed up.
Old Dec 4, 2007 | 12:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d0ugch0i &raquo;</TD></TR><TR><TD CLASS="quote">got it fixed. it turned out to be 2 spark plug wires that were messed up.</TD></TR></TABLE>
yea that could be a problem...anyone know why the subies sounds so weird?
Old Dec 4, 2007 | 12:47 PM
CB's Avatar
CB
Default Re: (VTEC_PRODUCTION)
i know they have a flat-four but not sure what causes there rumbling
Old Dec 4, 2007 | 01:03 PM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">
yea that could be a problem...anyone know why the subies sounds so weird?</TD></TR></TABLE>
Like the guy above said, subaru engines are "flat 4s" the pistons dont go up and down they go side to side. Heres a pic:
Old Dec 4, 2007 | 04:27 PM
Mr_Chopsticks's Avatar
I have the same problem and I had a guy at work look at it and he did a compression check. There was no compression in my 2nd cyclinder whatsoever and my sparks where fine. I'm wondering would it be a bent valve? I'm guessing my brother took it up too high when I let him get behind the wheel.
Old Dec 4, 2007 | 04:58 PM
d0ugch0i's Avatar
yea you gotta fix that then. if theres no compression on one cylinder it means your only running on 3 cylinders. should fix it asap. it could blow your motor so get it done fast.
Old Dec 4, 2007 | 08:45 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: (Mr_Chopsticks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Chopsticks &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem and I had a guy at work look at it and he did a compression check. There was no compression in my 2nd cyclinder whatsoever and my sparks where fine. I'm wondering would it be a bent valve? I'm guessing my brother took it up too high when I let him get behind the wheel. </TD></TR></TABLE>
Leak down test will tell you exactly where compression loss is coming from. If you dont know how to do one check google.
Old Dec 5, 2007 | 12:08 AM
d0ugch0i's Avatar
...now my car makes this really loud knocking noise in the back whenever im at low speeds and braking. what the hell is this.
Old Dec 5, 2007 | 12:37 AM
who knows man...brake dust shields?
gotta take a gander
or have someone stand outside and drive past them
Old Dec 5, 2007 | 06:09 AM
GRAF-FITI's Avatar
* B A N N E D *
gotta take a gander
haha who says that?
Old Dec 5, 2007 | 06:53 AM
teetee's Avatar
scubies also sound they way they do because of their uneven headers and how one side runs longer then the other to attach to the exhaust.
Old Dec 5, 2007 | 11:58 AM
LsVtecFoti's Avatar
my 98 automatic LS used to do the same thing, get your injectors/ spark plugs/wires checked. and if it continues to happen, your more than likely running on 3/4 cylinders. Mine turned out to be a mix of low gas and bad injectors. replace all 3 to be sure
Old Dec 5, 2007 | 03:05 PM
d0ugch0i's Avatar
yeup i found out what the clanking noise was alright. look what happened. one of my wheels fell off, my car hit and dropped to the floor, bent my back bumper, and wheel has stripped threads.
Old Dec 5, 2007 | 04:27 PM
denieone's Avatar
the firing sequence of the cylinders, I believe is 1/3 & 2/4 fire at the same time not like an inline 1,2,3 & 4.
Old Dec 5, 2007 | 08:03 PM
riceburner700's Avatar
Default Re: (denieone)
probably got water in the dizzy, check the points and see if they are corroded
Old Dec 5, 2007 | 09:40 PM
ls19integra95's Avatar
Default Re: (riceburner700)
do a compression test... mine did the same thing and i pulled my head off to rebuild it and found a valve on #1 cylinder had a piece missing from it... buddie also had same problem and it was bad plugs, wires and dizzy... so do compression test first...
Old Dec 5, 2007 | 09:44 PM
dimwitrj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teetee &raquo;</TD></TR><TR><TD CLASS="quote">scubies also sound they way they do because of their uneven headers and how one side runs longer then the other to attach to the exhaust.</TD></TR></TABLE>
Right. Put aftermarket headers on a Sube and it will sound like any run of the mill Honda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denieone &raquo;</TD></TR><TR><TD CLASS="quote">
the firing sequence of the cylinders, I believe is 1/3 & 2/4 fire at the same time not like an inline 1,2,3 & 4. </TD></TR></TABLE>
Wrong.
