LSD tranny installed.....Question???
Old Dec 3, 2007 | 07:57 AM
jdmkid8383's Avatar
Default LSD tranny installed.....Question???
ok the tranny is installed
1st gear GOOD
2nd gear GOOD
3rd gear ...............POPS OUT why would that be?
4th gear GOOD
5th gear GOOD
HELP!!
Old Dec 3, 2007 | 08:31 AM
AWD Terror's Avatar
Default Re: LSD tranny installed.....Question??? (jdmkid8383)
The search feature is your friend....
https://honda-tech.com/zerothread?id=2106004
https://honda-tech.com/zerothread?id=2138670
https://honda-tech.com/zerothread?id=2075149
Old Jan 3, 2008 | 06:50 PM
cody93's Avatar
Default Re: LSD tranny installed.....Question??? (AWD Terror)
the gears have a gear itsself and they also have tiny teeth that the sleeve slides over to engauge that gear after time it gets worn down and it pops out of gear you just neen a 3rd gear kit which includes a hub sleeve syncro and gear you can have it installed or you can do it yourself check everything else while you have it apart look for wear on the gears and sleeves
Rickvanuden
Transmission & Drivetrain
Jun 8, 2017 09:00 AM
lude98SH
Jun 15, 2008 11:04 AM
charjacq
Jul 27, 2004 01:13 PM
hooptie157
Oct 19, 2002 02:22 AM
