2003 motor swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userpaul5237 »</TD></TR><TR><TD CLASS="quote">that motor is bad does anyone know how hard it is to do on the ground</TD></TR></TABLE>
im not sure exactley what you are asking but i believe you are saying how hard is it to change motors without a car lift correct? ive never changed a motor in a honda suv but i wouldnt imagine it would be too far off from changing the motor out in any other honda car with the addition of having to remove the rear drive shaft which shouldnt be much work at all. if you have done some mechanical work in the past (change motors, clutch, what have you) then you should be fine, if not i suggest having someone else work on your newer vehicle or at least be there to help and guide you.
