Oil Problem in my 98 teg
Old Dec 3, 2007 | 04:56 AM
dudeomega2000's Avatar
Default Oil Problem in my 98 teg
I was driving the other day in my car and all of a sudden i see the oil light come on in my gauge cluster. I pull over and i stop the car and check the dipstick and i come to see that it is bone dry. I walk to the nearest autoparts store (becuase it was on a sunday and no mechanic is open on sunday) to buy some oil and i put it in... i go to see my friend who is a Honda expert to see what the problem is and he was stumped... the car is not smoking white even under the highest RPM and there is no visible leak of oil coming from the car. What can be happening?!
Old Dec 3, 2007 | 05:10 AM
AWD Terror's Avatar
Default Re: Oil Problem in my 98 teg (dudeomega2000)
Well it obviously didn't magicaly dry up.
It has to either be burnt or leaked.
Were you driving your car hard?
Old Dec 3, 2007 | 05:17 AM
1bad-eg's Avatar
Default Re: Oil Problem in my 98 teg (AWD Terror)
I agree, if it's not leaking it out, it's burning it.....
Old Dec 3, 2007 | 05:33 AM
Default Re: Oil Problem in my 98 teg (1bad-eg)
i know it didn't magically dry up... besides white smoke coming from the exhaust... how else can you tell that oil is burning. i dont drive my car hard but i do punch it in first and second from time to time that is about it
Old Dec 3, 2007 | 05:44 AM
AWD Terror's Avatar
blue smoke = oil
White smoke = coolant
black smoke = gas (too much)
If you are seeing white smoke, maybe your oil is leaking into the coolant system. This is unlikely b/c coolant would normally end up in the oil pan as well.
Old Dec 3, 2007 | 05:48 AM
i am not seeing any kind of smoke. and i can not see any oil leaking from anywhere. This is what u call a fortune cookie mystery. I can not see a leak and no smoke is coming from the exhaust even at high rpm... the car only has 109,xxx miles on it.
Old Dec 3, 2007 | 05:53 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dudeomega2000 &raquo;</TD></TR><TR><TD CLASS="quote">i am not seeing any kind of smoke. and i can not see any oil leaking from anywhere. This is what u call a fortune cookie mystery. I can not see a leak and no smoke is coming from the exhaust even at high rpm... the car only has 109,xxx miles on it.</TD></TR></TABLE>
There are such things as "thermal leaks". This is when a seal is going bad, and has small cuts in it. However, it holds until it gets too hot.
I would make sure it has enough oil, then allow your car to warm up. Rev it up a little, checking for leaks the whole time.
First thing to check with an oil leak, is your oil filter.
slammedz6ef's Avatar
your probly leaking from the pan! i had this problem on a few cars
Old Dec 3, 2007 | 06:00 AM
Thanks i will do... if any1 has other insight i would be more than happy to hear ideas
Old Dec 3, 2007 | 06:06 AM
cause if your not burning anything, i would replace the oil pan gasket, or check the drain bolt on the pan
Old Dec 3, 2007 | 06:13 AM
AWD Terror's Avatar
Default Re: Oil Problem in my 98 teg (slammedz6ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedz6ef &raquo;</TD></TR><TR><TD CLASS="quote">cause if your not burning anything, i would replace the oil pan gasket
STFU. That is the dumbest thing I've ever herd. If it needs replaced, you should see a big puddle of oil.
I would check the drain plug however, but that also would allow oil to leak out at any time.
Old Dec 3, 2007 | 06:16 AM
whoa whoa whoa watch the attitude
now im not going to try n help you
Old Dec 3, 2007 | 06:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">
I would check the drain plug however, but that also would allow oil to leak out at any time.</TD></TR></TABLE>
then your burning it
Old Dec 3, 2007 | 06:19 AM
GRAF-FITI's Avatar
* B A N N E D *
then your burning it</TD></TR></TABLE>
which was already said above
Old Dec 3, 2007 | 06:25 AM
Default Re: Oil Problem in my 98 teg (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
which was already said above </TD></TR></TABLE>
well he said "i am not seeing any kind of smoke. and i can not see any oil leaking from anywhere. This is what u call a fortune cookie mystery. I can not see a leak and no smoke is coming from the exhaust even at high rpm... the car only has 109,xxx miles on it."
Old Dec 3, 2007 | 06:26 AM
GRAF-FITI's Avatar
* B A N N E D *
just because he doesn't see the smoke doesn't mean it's not burning
Old Dec 3, 2007 | 06:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">just because he doesn't see the smoke doesn't mean it's not burning</TD></TR></TABLE> ............
Modified by slammedz6ef at 8:15 AM 12/3/2007
Old Dec 3, 2007 | 07:12 AM
AWD Terror's Avatar
Agreed
Anyone else having a problem with PM's?
Old Dec 3, 2007 | 07:50 AM
GRAF-FITI's Avatar
* B A N N E D *
Anyone else having a problem with PM's?</TD></TR></TABLE>
me!
Old Dec 3, 2007 | 07:59 AM
AWD Terror's Avatar
me!</TD></TR></TABLE>
You just gotta give the IM box the full 5 mins to load for the send button to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedz6ef &raquo;</TD></TR><TR><TD CLASS="quote"> ............
Modified by slammedz6ef at 8:15 AM 12/3/2007</TD></TR></TABLE>
What is this for? You don't think you car can burn oil without you seeing it?
Old Dec 3, 2007 | 08:07 AM
St Jimmy's Avatar
* B A N N E D *
How quick does the oil "vanish" Is it like a quart a day/week/month? It wouldnt hurt to try a compression check and make sure your numbers are good.
Andrew99911
Honda Civic (2001 - 2005)
Jul 5, 2017 11:46 AM
vmm
May 19, 2005 11:54 AM
MrPotatoeHead
Mar 16, 2005 05:26 AM
Honda97
Mar 10, 2005 05:06 PM
