motor noise in my 92 gs-r integra
Old Dec 3, 2007 | 12:38 AM
slammedz6ef's Avatar
Default motor noise in my 92 gs-r integra
when i first start it in the morning it has a rattling noise from the motor, then 2 minutes later it goes away and runs great and really quiet with no ticking or anything! anybody knows what it could be? it does it every moring i start it up, please help asap, i want to make sure its nothing major, thanks
Old Dec 3, 2007 | 12:45 AM
shake_em's Avatar
Default Re: motor noise in my 92 gs-r integra (slammedz6ef)
be more specific about the noise
Old Dec 3, 2007 | 12:53 AM
Default Re: motor noise in my 92 gs-r integra (shake_em)
ok, well it sounds a little like bad rod bearings, and it sounds like its comming from the block.......... but after two minutes it goes away, no cel, no smoke or anything, and still has its power
Old Dec 3, 2007 | 01:00 AM
shake_em's Avatar
dont take my word for it but it might be something with your exhaust. maybe something is loose like were your down pipe connects to your cat. when it warms up a bit the pipes expand and might titen up
Old Dec 3, 2007 | 01:02 AM
hmmmm i never thought of that lol
i also notice that it does it a little when i rev it to like 4k but you can barely hear it
Old Dec 3, 2007 | 01:05 AM
more info
for the first two minutes of it running in the morning when its under load the noise goes away, but comes back when i have the clutch in or in neutral...........
Old Dec 3, 2007 | 06:47 AM
scrooge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedz6ef &raquo;</TD></TR><TR><TD CLASS="quote">more info
for the first two minutes of it running in the morning when its under load the noise goes away, but comes back when i have the clutch in or in neutral........... </TD></TR></TABLE>
sounds like the same problem i had i used to have a 92 gsr RIP got rear ended..i get side tracked to easily lol anyways when being started in the morning or in neutral at a traffic light you cant really hear it but its still there. When you rev it to 3.5k to 4.5k in any gear including neutral you hear it rattling. first i thought it was my heat sheild but then turns out it was my downpipe one of the nuts were gone so check your exhaust system
Old Dec 3, 2007 | 07:00 AM
Default Re: motor noise in my 92 gs-r integra (scrooge)
alright, thanks bro! ill have to check that out.
Old Dec 3, 2007 | 11:32 PM
shake_em's Avatar
same prob it sounds like https://honda-tech.com/zerothread/2166924
Old Dec 3, 2007 | 11:39 PM
i already took the sheild off bro, it still does it lol
Old Dec 4, 2007 | 05:39 AM
jhammond_82's Avatar
Reject Papi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedz6ef &raquo;</TD></TR><TR><TD CLASS="quote">hmmmm i never thought of that lol
i also notice that it does it a little when i rev it to like 4k but you can barely hear it</TD></TR></TABLE>
mine did that for a while, for about 2 months, and then it spewed its guts through the oil pan. get that checked out. not to say thats what it is but....
Dekorum
Feb 16, 2014 08:28 PM
Dev90gs
Oct 23, 2006 08:38 AM
Dev90gs
Oct 20, 2006 07:08 AM
GsDAteg
Mar 18, 2006 12:40 PM
djpuffball
Nov 13, 2001 01:13 PM
