P73 ECU question
Old Dec 2, 2007 | 08:19 PM
creepy116's Avatar
Default P73 ECU question
I have a 99 civic with a 97 itr motor with an OBD2A ecu. I was wondering if i could use an OBD2B p73 ecu?
Old Dec 2, 2007 | 08:22 PM
Padawan's Avatar
Darth ModerVader
Default Re: P73 ECU question (creepy116)
Not without a conversion harness.
Old Dec 2, 2007 | 08:34 PM
creepy116's Avatar
Default Re: P73 ECU question (Padawan)
my car is OBD2B and the ecu i was asking about is also OBD2b(p73) but the motor is 97 spec which is OBD2A
Old Dec 2, 2007 | 08:45 PM
Padawan's Avatar
Darth ModerVader
How are you currently running the 2A ECU in your car?
Old Dec 2, 2007 | 08:55 PM
creepy116's Avatar
i dont have the ecu in yet if i wanted the OBD2A ecu in there i would get an OBD2B-OBD2A conversion harness. But if it's possible to run the p73 OBD2B ecu in my car just fine then i will trade my ecu for that one
Old Dec 2, 2007 | 08:56 PM
Padawan's Avatar
Darth ModerVader
It's possible, but you will need to disable the immobilizer system on the ECU.
Old Dec 8, 2007 | 01:25 PM
RhdRicheeee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">It's possible, but you will need to disable the immobilizer system on the ECU. </TD></TR></TABLE>
just get the jdm obd2b p73 ecu
