msd ignition (gsr)
Old Dec 2, 2007 | 07:39 PM
almerricking's Avatar
Default msd ignition (gsr)
i dont know where my other post went but anyways i blew my msd ignition on a swap. i guess i ran the pos and neg wires backwards but anyways i wanted to go back to oem anyways. so i got an ignition coil, rotor, and cap at autozone and hooked it up with no success. im guessing that the wires are hooked up wrong from the msd ignition. right now i have the third wire coming from the icm going into the pos of the coil and coming from the harness there is a wire tapped into a
?black/red? that i hooked up for the negative. these were the two wires used for msd.
but anyways. still no spark and im not picking up any resistance on either the coil or icm. so anyways my question is can someone insure my wiring and tell me if i can use my d-series icm on a b18?
cool thanks
Old Dec 2, 2007 | 08:15 PM
PinoyDelSol's Avatar
* B A N N E D *
Default Re: msd ignition (almerricking)
i have a fresh MSD box with the 2step for 200 bucks...!
Old Dec 2, 2007 | 08:20 PM
lol thanks but going stock is going to be the fastest route for me. also i forgot to say i think i fried the fuse and i dont have my panel so i dont know the location of the fuse...if anyone has a print out of the fuse panel that would be cool. i havent located one yet.
Old Dec 2, 2007 | 08:25 PM
* B A N N E D *
oh alrights, what car do you own? Maybe i have a picture of a fuse panel.
Old Dec 3, 2007 | 03:54 AM
its a 96 ex but i ended up finding a fuse layout..now i just need the wiring for the icm and ignition coil. and whether or not my d series coil and icm will work with this gsr.
Old Dec 3, 2007 | 03:58 AM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almerricking &raquo;</TD></TR><TR><TD CLASS="quote">its a 96 ex but i ended up finding a fuse layout..now i just need the wiring for the icm and ignition coil. and whether or not my d series coil and icm will work with this gsr.</TD></TR></TABLE>
they will work, msd is junk... its not needed unless your boosted and making over 600+whp
Old Dec 3, 2007 | 05:05 AM
thank god i didnt open up the $200 worth of coils and icm from autozone yet...i guess i can get the wiring off my old engine (that i had to cut the rotor off of because the bolt was stripped). hopefully i can get this thing started tonight then.
redlinez_r_us
May 28, 2010 12:05 PM
B18cFreak
Jul 30, 2008 01:26 PM
Rodzknight
Jul 3, 2006 01:02 PM
turbohf
May 21, 2006 11:02 PM
juicedh22
Oct 9, 2004 05:45 AM
