Big Tube Hytech
Old Dec 2, 2007 | 06:16 PM
JakeSpec's Avatar
Default Big Tube Hytech
Does anyone have one? Any Dyno Charts? any Pros? any Cons? recommend a better A/M Header?
(14:5:1 86mmx89mm Setup)
About to get one next Week!
Any Feedback is greatly appreciated!
Old Dec 2, 2007 | 06:44 PM
gator88's Avatar
Default Re: Big Tube Hytech (JakeSpec)
I dont know if you want my input or not, but this is it.
I have the same thing on my dirtbike, made by FMF, they have two versions. A megabomb and a powerbomb. I have a powerbomb which looks identical to that header. It allows the exhaust gases to cool and move out faster, gives the torque of a long header and over rev of a short one. This is all dirtbike related, but the design is identical and i love it. it is a very efficient and works great, gives both low end and top end. If it works anything like that for a car, i would def. get one!! There is my 2 cents.
Old Dec 2, 2007 | 06:50 PM
JakeSpec's Avatar
Default Re: Big Tube Hytech (gator88)
thanks bro for the info, i was wonder what the purpose of the larger tube was, now i know, and knowing is half the battle, lol
but yeah no BS Todd @ Church Said hands Down Over RMF and ANR for my exact setup!
im trying to hit 260+ @ church but i need this Header first
thanks for the feedback!
Old Dec 2, 2007 | 07:28 PM
p10hlm's Avatar
i know that isnt your car but it looks like the bottom of the header hits that oil pan
Old Dec 2, 2007 | 07:33 PM
boosstboy's Avatar
Default Re: Big Tube Hytech (p10hlm)
test done by VtecKiDD https://honda-tech.com/zerothread/1269372
NEVER GOING TO HAPPEN
Test 1
TEST ENGINE:
JDM B18C Integra Type-R STOCK
PLACING:
1st RMF NARROW 4-1 185.61whp/128.49TQ
2nd SMSP Prototype 4-1 184.70whp/128.98TQ
3rd SMSP 4-2-1 182.38whp/123.82TQ
4th ANR w/Merge 181.05whp/125.79TQ
5th DTR B-Unit 180.82whp/125.46TQ
6th Hytech Production 180.63whp/124.19TQ
7th DC JDM 4-1 174.24whp/124.04TQ
Modified by VtecKiDD at 1:44 AM 11/30/2007
i dont believe this was their big tube header, could be wrong.
Old Dec 2, 2007 | 09:44 PM
alscrx's Avatar
Default Re: Big Tube Hytech (boosstboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p10hlm &raquo;</TD></TR><TR><TD CLASS="quote">i know that isnt your car but it looks like the bottom of the header hits that oil pan </TD></TR></TABLE>
That header sure does hit the corner!!
Old Dec 2, 2007 | 11:55 PM
NastyHabitzCRX's Avatar
Default Re: Big Tube Hytech (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> well it does have a moroso pan, im sure a stocker would clear. looks nice though (to the op) cant wait to see your setup
Old Dec 3, 2007 | 04:35 AM
ludesrv's Avatar
We ran one on our 86mm X 89mm 'Big B' setup. Made 262whp.
The header helped. We picked up a few HP at the wheels with just the header. But again we were at 16.5:1 compression on nothing but race fuel.
Engine was blown up on the dyno by the tuner or was improperly built by the build (we were too scared to build it ourselves). Only made 3 untuned run of a best 12.3 granny shifting on a GSR tranny.
I'm an all motor guy and I can tell you a GOOD header can add significant gains on a built engine.
Old Dec 3, 2007 | 08:05 AM
JakeSpec's Avatar
Default Re: (ludesrv)
my last setup was 16:8:1 with Wiseco Super Duper Ultimate IB SPEC pistons i love that motor, lasted 2 years and about 50+ passes!with a 7.49 1/8 mi on 240, Fn great motor, but now i dropped down to the 14 comp. im on F&L SP3 fuel and the motor feels way stronger than the 16 comp. and also made more power!, todd @ church said he would recommend the large tube hytech for my setup cause the bisi header is choking the top end after 9300 so i should see some better mid range and way better top end power with these. just need to get my *** over to Irvine to pick them up,
thanks for the info guys!
Old Dec 3, 2007 | 08:10 AM
JakeSpec's Avatar
your dyno test was the production header that header was weenie this is the BIG TUBE HYTECH that larry sells @ ENDYN
and its also in the Nov Issue of Honda Tunning
Hytech In Irvine Ca 30 minutes away has them shelved In Stock
Old Dec 3, 2007 | 10:48 AM
Disco Monkey's Avatar
Hytech headers hang very low in EF's.
SMSP makes a big tube header that has better ground clearance and still makes good power.
It might be something to consider.
Good luck with your build.
Old Dec 4, 2007 | 06:21 AM
Bisimoto's Avatar
Default Re: (JakeSpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec &raquo;</TD></TR><TR><TD CLASS="quote"> todd @ church said he would recommend the large tube hytech for my setup cause the bisi header is choking the top end after 9300 so i should see some better mid range and way better top end power with these. just need to get my *** over to Irvine to pick them up,
thanks for the info guys!</TD></TR></TABLE>
I am shocked that Todd would make such a horrible biased claim without data...after all our units are custom made to a customer's build, and my dissatisfaction with Hytech header designs (especially the $1500 ones) forced me into the header scene.
It is too bad that people do not understand the science behind our designs. Then again, it is human nature to fear what one does not understand.
Old Dec 4, 2007 | 06:28 AM
89civicdx's Avatar
Default Re: (Bisimoto)
Why does everyone make the headers hang so low? looks like theres so much room to tuck it up
Old Dec 4, 2007 | 07:20 AM
iwantspeed's Avatar
Default Re: (89civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Why does everyone make the headers hang so low? looks like theres so much room to tuck it up</TD></TR></TABLE>
well there isnt... or it would be.
Old Dec 6, 2007 | 08:07 AM
racecar chassis builder's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 &raquo;</TD></TR><TR><TD CLASS="quote">I dont know if you want my input or not, but this is it.
That can on the bike is for sound only.Its to quiet it down and thats it.Also when exhaust cools it slows down ,Not speeds up.
Old Dec 6, 2007 | 08:14 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bisimoto &raquo;</TD></TR><TR><TD CLASS="quote">
It is too bad that people do not understand the science behind our designs. Then again, it is human nature to fear what one does not understand.</TD></TR></TABLE>
I stand firmly behind my opinion that Bisi headers are the best on the planet for honda B series and D series. Bar NONE.
Old Dec 6, 2007 | 08:25 AM
Aquafina's Avatar
Hytech was not Larry's first choice for the engine he built for Honda Tuning. He only used that because of a personal beef with another header builder.
Dave @ SMSP built a custom big tube 4-1 for my D16. Untuned on a stock engine (header is way too big for a stock engine), I got 3 tenths off my 1/4 and picked up 4mph.
PPLH8R
Welding / Fabrication
14
Jan 20, 2008 11:58 AM
an2ny888
Sep 16, 2005 05:45 PM
gsrhatch1126
May 11, 2005 08:54 AM
RobbieG35
Mar 13, 2004 01:08 AM
sackdz
Oct 18, 2001 09:54 AM
