What's everybody running suspension wise?
Old Dec 2, 2007 | 04:24 PM
Vp Special K's Avatar
Default What's everybody running suspension wise?
i wanna see some set ups and hear some feedbacks on everybodys suspension
Old Dec 2, 2007 | 04:26 PM
Hawkze_2.3's Avatar
Default Re: What's everybody running suspension wise? (Vp Special K)
D2 coilovers, Progress rear bar, PFI traction bar, 15" Volk TE-37s, etc...
Old Dec 2, 2007 | 04:43 PM
SnlpeR's Avatar
tein flex 10k/8k rates
progess rear swaybar
custom endlinks
neuspeed upper tower bar
a few prothane bushings in the front
a couple sets of 15x7s on slicks
15s, 16s, 17s
etc
pic shows the old tein ss
i dont thnk i took a pic of the flex on the car
Modified by SnlpeR at 1:57 AM 12/3/2007
Old Dec 2, 2007 | 05:14 PM
prelude-all-the-way's Avatar
Default Re: (SnlpeR)
function and form type 1
neuspeed strut bar
16" rota circuit 8s
will get pics up later
Old Dec 2, 2007 | 05:15 PM
Ludster's Avatar
I'm on Function/Form Type I 13k/7k
16" Slipstreams with RT-615s 215/45/16
I'm trying to figure out which sway bar I should run.
Old Dec 2, 2007 | 05:29 PM
E-Money's Avatar
Default Re: What's everybody running suspension wise? (Ludster)
Koni yellows 5 way adjustable
Eibach pro kit springs
New OEM rear end links, sway bar bushings in the front and rear.
Use to run the Progress bar with the Progress end links. Too noisy for street use.
Old Dec 2, 2007 | 05:51 PM
SnlpeR's Avatar
yeah the progress endlinks suck
it rode good for 2 days then the noise came
i did so many things to them to get them to stop knocking...
it worked...but only for a couple of weeks...then the noise came back again
spent the 80 bucks for new rod ends
Old Dec 2, 2007 | 05:56 PM
E-Money's Avatar
i found out after i removed the bar that i was riding with a broken one for sometime ha.
Old Dec 2, 2007 | 06:19 PM
rich045's Avatar
* B A N N E D *
Default Re: (E-Money)
gab street shocks
gab race springs
Old Dec 2, 2007 | 06:25 PM
VTecLude1994's Avatar
Default Re: (rich045)
5Zigen R-Rated Springs
Tokico HP Shocks/Struts
Megan Front & Rear Upper Strut Bar
I really don't push the car that often but just driving around is pretty comfortable.
Old Dec 2, 2007 | 08:51 PM
jmai86's Avatar
Default Re: (VTecLude1994)
Neuspeed Koni Yellows
Neuspeed Race springs
Perfect for the street
Old Dec 2, 2007 | 11:11 PM
pprowler6's Avatar
Default Re: (jmai86)
im runnin d2 coilovers and soon a progress rear swaybar
Old Dec 3, 2007 | 12:25 AM
Diao's Avatar
Skunk2 Springs (awful)
KYB AGXs (great)
Spoon Sports front+rear strut bars
Drag DR16 16x7 +40
Dunlop Direzza 215/45/16 (excellent tires)
I'm switching to a Tein setup after winter, I just can't stand these damn Skunk2 springs any longer. Still debating between ST or Progress sway bars.
Old Dec 3, 2007 | 06:17 AM
nonvteclude's Avatar
Default Re: (Diao)
tein flex
suspension technique F&R sway bar
nuespeed front tower bar
cusco rear tower bar
energy suspension poly bushings (black)
tenabe F&R lower frame braces
ESP traction bar
hankook hrII tires
car holds really well into corners and rides really nice for everything done.
Modified by nonvteclude at 2:01 PM 12/3/2007
Old Dec 3, 2007 | 06:21 AM
johnny five's Avatar
Tanabe S-Zero full coilovers with pillow mounts (used from ebay)
Cusco front and rear upper strut bars (used from ebay)
Tanabe rear lower tie bar
Suspension Techniques f&r sway bars
5 lug conv. with 5th gen wheels
The setup is pretty stiff, the backend has comeout on me once, I think that may have to do with the conversion because the wheels in more like a higher offset so its width is narrower. So I will be trying 15in wheels with a +38 offset and see what that does. I think the ST front sway bar maybe causing that as well. Other then that I like it.
Old Dec 3, 2007 | 11:32 AM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
Default Re: (johnny five)
Koni Yellow's with GC springs
440 Front
380 Rear spring rates.
Love the ride. Even in the snow and ice it handles good and very little noise.
Wont know how she really handels until next year at autox.
Soon to come. 15" wheels (still not sure what kind) and Falken RT 615's
Old Dec 3, 2007 | 12:35 PM
117's Avatar
117
Default Re: (CAN97SH)
I have some 15x7, +38mm, 5x114.3mm Kosei K1s for sale. Brand new, never used or installed. I can't use them with my brake kit, so I have to sell them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAN97SH &raquo;</TD></TR><TR><TD CLASS="quote">Soon to come. 15" wheels (still not sure what kind) and Falken RT 615's </TD></TR></TABLE>
So I don't get flamed for hijacking, my setup is Koni race shocks with Hypercoil springs and custom upper mounts.
Modified by 117 at 4:11 PM 12/3/2007
Old Dec 3, 2007 | 01:06 PM
f22builder's Avatar
tokico illumina series 5way adjustable springs and struts (always on 5)
1.5 dropfr 1.2 rear
neuspeed upper front tower bar
was Suspension tech.'s front/rear sways until rear ripped mounting bracket off.
no one wants to weld back there (gas tank) switched to Progress rear bar.
replace all bushing with oem.
crappy 17 swedish rims..but they only weigh 12lbs each.
car handles great with little neg. camber
I recommend smaller rims and taller and wider tires.
Old Dec 3, 2007 | 01:51 PM
gotjnco's Avatar
Default Re: What's everybody running suspension wise? (f22builder)
NRG dual ride height adjust ability
4-way dampening control with upper mounts
12k/10k spring rates
F+R ST Sway bars...
F+R Spoon Sports Strut Bars
rides awesome
Old Dec 3, 2007 | 04:12 PM
my9thtry's Avatar
Default Re: What's everybody running suspension wise? (gotjnco)
Pro-kit/koni yellow, progess rear bar
JAYBOOGIEZZ
May 10, 2007 10:29 AM
lOOkatme
17
Nov 5, 2003 07:44 PM
lOOkatme
Nov 3, 2003 07:46 AM
Ohlias
Oct 31, 2002 01:20 PM
Razor
May 4, 2002 12:27 PM
