Rear Disk Conversion
Old Dec 2, 2007 | 04:18 PM
deaton333's Avatar
Default Rear Disk Conversion
I've searched and haven't found an exact answer. I'm trying to do a disk conversion on my 1988 CRX. I know that the rear brakes from a dc integra will work. I just need to know if I can use the rear trailing arm or do I need to use my trailing arm. I'm thinking I need to use my arm, just wanna make sure.
Old Dec 2, 2007 | 04:21 PM
CRX Toad's Avatar
Default Re: Rear Disk Conversion (deaton333)
Either. But I would just use the DC one. There is a lot of good stuff in the FAQ also check out Fourth Gen Site in the FAQ.
Old Dec 2, 2007 | 04:22 PM
deaton333's Avatar
Default Re: Rear Disk Conversion (CRX Toad)
I checked out all of the faqs. Couldn't find anything about the dc rta. Found a lot on the da arm.
Old Dec 2, 2007 | 04:27 PM
alscrx's Avatar
Simple swap just grab the whole arm your getting the rear disc swap from.
Also you should get the crx si e brake cables so its a perfect fit.
Da's are too long but work. Everything bolts right in! Make sure you have the disc brake hoses too cause drum hoses are different
Old Dec 2, 2007 | 04:32 PM
deaton333's Avatar
Default Re: Rear Disk Conversion (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">Da's are too long but work. Everything bolts right in! Make sure you have the disc brake hoses too cause drum hoses are different</TD></TR></TABLE>
I'm trying to use the dc rear arm. Will it work?
Old Dec 2, 2007 | 09:48 PM
alscrx's Avatar
Yes the DC will bolt on!
but do you have the correct ebrake cables????
Old Dec 2, 2007 | 10:36 PM
Zaakro's Avatar
I just did a rear disk break conversion it was a piece of cake. Just don't for get to change out the TA bushings
Old Dec 3, 2007 | 02:37 AM
deaton333's Avatar
Default Re: Rear Disk Conversion (Zaakro)
Yeah, I'll get the e brake cables. I knew I needed the si cables.
socalrex88
Jul 17, 2007 03:08 AM
bmoua
Aug 21, 2006 11:15 PM
QuickRexSi21
19
Feb 24, 2006 02:29 PM
CLE
Feb 22, 2006 07:30 PM
NsX_CrX
May 28, 2004 08:21 AM
