ngk or msd
Old Dec 2, 2007 | 04:15 PM
Blazen_angles's Avatar
Default ngk or msd
witch spark plug and wire would be better for my 89 turbo crx
Old Dec 2, 2007 | 04:16 PM
JDM_DC4_Fanatic's Avatar
Default Re: ngk or msd (Blazen_angles)
which msd wires? there is a 8MM and 10mm wire avalible. Unless you upgrade to the 10MM wires, and have a better coil to back it up, go with the NGK because it will be cheaper.
Old Dec 2, 2007 | 04:29 PM
SFlCrx's Avatar
oem ngk can handle more then you can ever make
Old Dec 2, 2007 | 04:34 PM
alscrx's Avatar
Default Re: (SFlCrx)
NGK only way to go
Old Dec 3, 2007 | 05:40 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
MSD makes 8 and 8.5 mm wires, not 10. MSD doesn't make a bad wire, but they usually are more costly then the NGK counterparts which still perform as well. I bought a set of MSD's cause I got them at a deal, but the NGK is more then likely the cheaper route.
Old Dec 3, 2007 | 06:08 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFlCrx &raquo;</TD></TR><TR><TD CLASS="quote">oem ngk can handle more then you can ever make </TD></TR></TABLE>x2 individual coilpacks ftw though.
Old Dec 3, 2007 | 04:11 PM
SFlCrx's Avatar
Default Re: (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">x2 individual coilpacks ftw though. </TD></TR></TABLE>
not everone has a K bart . one day i will tho and that will be the day i soil myself
Old Dec 5, 2007 | 06:07 AM
CRXBart's Avatar
not everone has a K bart . one day i will tho and that will be the day i soil myself</TD></TR></TABLE>
People can convert B's to individual coil packs. Hell I remember back in the day, JinxProof99 on here was running a Mitsu coil pack, but it required plug wires. I just despise distributors. I have had too many go out over the years, ruin my day, and **** me off. If I ever do another B or D, it will be boosted, and not use a distibutor.
Rob.
23
Oct 12, 2007 08:39 AM
vtek9
Aug 24, 2007 11:34 PM
De_tour
10
Mar 5, 2006 07:05 PM
ramz7887
80
Apr 14, 2004 12:56 PM
crxsirvtec
Sep 15, 2003 11:24 AM
