clutch noise.
Old Dec 2, 2007 | 04:14 PM
slo_ej8's Avatar
Default clutch noise.
There is a weird sorta scraping noise when the clutch pedal is up.
When I push it down it goes away completely.
Any idea what it is?
Thanks.
Car is a 2000 civic ex. EJ8 with stock clutch.
Old Dec 2, 2007 | 04:20 PM
924doorEG's Avatar
throw out bearing or main bearing in the tranny.
Old Dec 2, 2007 | 04:24 PM
BLinindoll's Avatar
Default Re: (924doorEG)
throw out bearing would only make noise when clutch pedal is down. bearing in the tranny makes sense though.
Old Apr 20, 2008 | 01:53 PM
RaWrZie's Avatar
Default Re: (BLinindoll)
First of all.
Sorry for reviving.
But I DID find this by SEARCHING!
Anyway...I have the same problem.
Clutch is up so that means throwout bearing in transmission.
So does that technically mean I need a new transmission?
Old Apr 20, 2008 | 02:28 PM
Kurly's Avatar
Default Re: (RaWrZie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaWrZie &raquo;</TD></TR><TR><TD CLASS="quote">First of all.
Sorry for reviving.
no, the t/o bearing is actually located on the clutch. however i would upgrade the clutch/flywheel while u have the tranny off.
Old Apr 20, 2008 | 02:39 PM
RaWrZie's Avatar
Default Re: (Kurly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kurly &raquo;</TD></TR><TR><TD CLASS="quote">no, the t/o bearing is actually located on the clutch. however i would upgrade the clutch/flywheel while u have the tranny off. </TD></TR></TABLE>
Cool. Is it expensive?
I'll look through my Haynes manual and find exactly where it is. Works wonders by the way. Who ever doesn't have one...get one. About $20. Mine was $17 at Autozone.
I should replace the clutch AND flywheel? Haven't got the tranny off but I guess I should do it anyway.
Thanks Kurly.
Old Apr 20, 2008 | 02:45 PM
Kurly's Avatar
You dont have to i would though since youll have to take the tranny off.
with a decent clutch, flywheel i would think no more than $300 (could be wrong)
when my old gsr hatch's t/o bearing went out (along with the death of my tanny) i bought another gsr tranny, l/w flywheel & a stage 3 clutch. pulled so f*cking hard haha
Old Apr 20, 2008 | 02:53 PM
RaWrZie's Avatar
Default Re: (Kurly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kurly &raquo;</TD></TR><TR><TD CLASS="quote">You dont have to i would though since youll have to take the tranny off.
when my old gsr hatch's t/o bearing went out (along with the death of my tanny) i bought another gsr tranny, l/w flywheel & a stage 3 clutch. pulled so f*cking hard haha</TD></TR></TABLE>
Haha. Sounds cool.
Now to save $300+.
Old Apr 20, 2008 | 03:04 PM
Kurly's Avatar
Dont think of it as saving..
think of it as, "time to get a baller *** clutch and flywheel!".
Old Apr 20, 2008 | 03:17 PM
RaWrZie's Avatar
Default Re: (Kurly)
Will do.
Old Apr 20, 2008 | 04:02 PM
jdeemseerx's Avatar
Sorry to burst your fun, happy bubble but its most likely your Input Shaft bearing.. Which means you buying a new clutch/flywheel setup is a waste of time. These bearings are notorious in honda trannies for taking a dump..In order to replace this 15 dollar bearing you have to completely disassemble the trans. So before you go buying just the clutch/flywheel which is a good idea while the trans is off anyway, i would also buy the bearing and read up on how to replace it. GL
Old Apr 20, 2008 | 05:30 PM
project4dr-eg's Avatar
Default Re: (jdeemseerx)
eh same problem here.glad i almost done paying the stang off; so i can get this damn k20 swap, hopfully tranny wont sh*t on me.
Old Apr 20, 2008 | 05:49 PM
RaWrZie's Avatar
Default Re: (project4dr-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project4dr-eg &raquo;</TD></TR><TR><TD CLASS="quote">eh same problem here.</TD></TR></TABLE>
Which problem?
The throwout bearing?
Or...
The input shaft bearing as jdeemseerx said?
Vt3c_eg
Apr 28, 2008 11:31 AM
LSVTEC 91 Civic
14
Sep 23, 2006 09:47 PM
vlc92189
Jul 23, 2006 05:01 PM
Edmund4th
May 18, 2004 03:43 PM
thatdamngood
12
Mar 17, 2004 09:03 PM
