B16 CRX Si misfire problems
Old Dec 2, 2007 | 03:23 PM
floridarex's Avatar
Default B16 CRX Si misfire problems
Ok i've got a obd-0 b16a in my crx, the car misfires randomly, example, at highway speed 65mph at 4000 rpms the car will cruise for a long time, for about
30-45 min. then all of a sudden it feels as though I'm only running on three cylinders, I give a little gas and it comes out of it, then when I let the rpms drop back down to 4000 it does it again, I have to run the car at 4500 rpms for it not to misfire. Also now when I start out in first, and I nail the gas as soon as it hits 7100rpms it's like it hits a fuel cut and the tach needle goes nuts, then when I get it to second and SLOWLY give it gas it will go all the way to redline. This doesn't make any since, I replaced the cap, rotor, plugs, wires, fuel filter, checked timing, checked for codes, sensors are good, no loose connections, checked the battery, alternator, everything checks out, I'm thinking it's my distributor, especially with the way the tach signal jumps, funny thing is it doesn't do this all the time. Any suggestions would be greatly appreciated.
Old Dec 2, 2007 | 04:34 PM
alscrx's Avatar
Default Re: B16 CRX Si misfire problems (floridarex)
Could be your dizzy, But when my needles went nuts like that it was my alternator going bad.
Maybe its just your coil. Do some tests on it with a voltmeter
Old Dec 3, 2007 | 04:22 AM
floridarex's Avatar
Default Re: B16 CRX Si misfire problems (alscrx)
Thanks for the info, I'll check it out today.
Old Dec 3, 2007 | 06:28 AM
redboy183's Avatar
yeah im pretty sure itd be your dizzy...my needles are jumpy like they are on crack everytime i had dizzy probs on all my cars
Old Dec 3, 2007 | 07:19 AM
B16PIMP's Avatar
http://i15.photobucket.com/alb...a.gif
Old Dec 4, 2007 | 05:42 AM
floridarex's Avatar
Default Re: B16 CRX Si misfire problems (redboy183)
IS DISTRIBUTOR KING A GOOD REPUTABLE PLACE TO GET THE DISTRIBUTOR?
DOES ANYONE HAVE EXPERIENCE DEALING WITH THIS SELLER?
crxfreak1117
Feb 9, 2007 01:15 PM
LankorDie
24
Sep 17, 2006 01:59 AM
EFin' Kyle
Dec 18, 2004 09:40 PM
roughrydin89
May 18, 2003 12:33 AM
omniracer23
May 14, 2002 01:51 PM
