why wont car shift on 1991 accord
Old Dec 2, 2007 | 02:40 PM
gang1ster's Avatar
Default why wont car shift on 1991 accord
I took my car to shop becouse my car kept overheating
and my friend took my water pump and timming apart to check out the problem.
I got it fixed but when I got car back the (Problem: car wont shift into gearby its self any more )
the guy at the honda shop told me that the shifter box went bad and i need to replace it.
is there such thing as a shifter box and what can do 2 fix this problem?
Old Dec 4, 2007 | 11:19 PM
RTT8's Avatar
What they meant by shifter box is probably the transmission. If it's the tranny, it could be a variety of things, tcm, fluid level....but first I would do a fluid flush if you haven't done so. Can't think of anything else off the top of my head, I'm sure others can chime in.
Old Dec 5, 2007 | 11:39 AM
Anomie's Avatar
Default Re: why wont car shift on 1991 accord (gang1ster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gang1ster &raquo;</TD></TR><TR><TD CLASS="quote">I took my car to shop becouse my car kept overheating
I got it fixed but when I got car back the (Problem: car wont shift into gearby its self any more )the guy at the honda shop told me that the shifter box went bad and i need to replace it. is there such thing as a shifter box and what can do 2 fix this problem?</TD></TR></TABLE>
If the car was shifting just fine before you took it to the shop and then you had problems shifting after you got the car.
IT SOUNDS LIKE YOU GOT TOOKEN
Old Dec 10, 2007 | 02:55 PM
tram1666's Avatar
you need a control box for the trans, mounted under floor on pass. side. you can use controller from 90 to 93 any model. if you use from 92 or 93 S button will not work & S light will stay on
chansta
Nov 19, 2010 09:19 AM
druxboyz
Mar 15, 2009 06:42 PM
crxhybrid85
Aug 17, 2006 02:55 PM
extensioncordy
Jun 22, 2006 08:21 AM
OE812
Oct 26, 2005 12:27 PM
