d15b flywheel bolt problems HELP!
Old Dec 2, 2007 | 10:32 AM
regal1975's Avatar
Default d15b flywheel bolt problems HELP!
I recently purchased an exedy clutch and Fidanzaz flywheel for my d15bvtec motor in an 89 crx. I attempted to reuse the stock bolts and they quickly stripped out..
My questions:
What is the flywheel to crankshaft torque spec?
Are bolts stamped "AT" meant for Automatics? Is this why my bolts stripped?
I purchased ARP bolts to replace the stockers and dont want to detroy those when they arrive, so I want to be sure and torque them to the proper spec.
Thanks!!!
Also, should there be any play at all in the clutch-input shaft connection?? I can put the clutch on the input of the stock DX tranny and it is very snug, on the SI tranny there is a just a slight, very slight play to it... the splines are perfect, but I dont want to cause problems...
Old Dec 2, 2007 | 02:03 PM
Donkey85's Avatar
Default Re: d15b flywheel bolt problems HELP! (regal1975)
hey man its 87ft- lbs annd remember to do a crisscross pattern when tightening them. just like when you put a tire on good luck
Old Dec 2, 2007 | 02:17 PM
regal1975's Avatar
Default Re: d15b flywheel bolt problems HELP! (Donkey85)
lol.. that explains why my bolts stripped.... genius shadetree mech (who has been a godsend so far outside of this one foul up) told me to use my impact gun to put them on... im guessing 280lb ft was a little outside of the acceptable range...
Thanks a ton!
angrysmileyface
Sep 14, 2014 05:09 AM
profishr
11
Dec 1, 2010 07:06 AM
dadrought6
Feb 22, 2009 11:00 AM
lsvtec101
Jun 7, 2004 09:52 AM
integraautox
Apr 4, 2003 08:36 AM
