brake booster leaking
if it's between, check to make sure the master isn't leaking causing the seal to go out. their should a seal between the master and the booster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi »</TD></TR><TR><TD CLASS="quote">anyone have any ideals on how to seal up a vac leak coming from inbetwen the m/c and the brake booster.</TD></TR></TABLE>
There should be a rubber gasket in there. Check to make sure it is intact.
yea its there but dont look like its in good condtion.i put a other one i had as a spare and it still seems to leak.would a vac leak inbetween them two will cause my car to run like ***.i mean it runs so bad when i stop hit l/c and drop the clutch instaed of spining the tires it just boggs down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi »</TD></TR><TR><TD CLASS="quote">yea its there but dont look like its in good condtion.i put a other one i had as a spare and it still seems to leak.would a vac leak inbetween them two will cause my car to run like ***.i mean it runs so bad when i stop hit l/c and drop the clutch instaed of spining the tires it just boggs down.</TD></TR></TABLE>
huh?
huh?
