93 power steering removal
Old Dec 2, 2007 | 09:30 AM
GG-SquadDB's Avatar
Default 93 power steering removal
I need some help seeing if this is possible i know the ITRs dont have power steering and i need some tech advice as to how to properly remove it and not have any problems? any help is greatly appriciated
Old Dec 2, 2007 | 09:57 AM
tsdneil's Avatar
http://g2ic.com/tegtips/engine/23.html
Old Dec 2, 2007 | 11:53 AM
jhammond_82's Avatar
Reject Papi
Default Re: 93 power steering removal (GG-SquadDB)
why don't you want power steering? it is convenient, especially in those tight fit parking lots, or in drive through's. lol
Old Dec 2, 2007 | 01:58 PM
Fern413's Avatar
Default Re: 93 power steering removal (jhammond_82)
i would leave it alone...the best way to remove your power steering is to change it to a manual steering rack..w/o power steering..g/l tho
Old Dec 3, 2007 | 03:08 PM
lsda9's Avatar
You can remove your pump, cooler, resevoir and all your lines. And with the parts you removed you can loop the lines by cutting some of the hardlines and adding some hoses.
FIX
FIX
I dont know if the picture posted. But, anyways. There are 4 fittings on the valve body connected to the steering rack, 2 of them are 12mm, 1 is 14mm, and the other is 17mm. You want to loop together the 12mm together, you can do this by cutting 4-5 inches or so up the hardline where it bends( I suggest a small hacksaw if you have it-it will keep the line from getting clamped shut by snips). Then you are going to want to loosen up the fittings so that the lines will spin inside the fitting with out the fitting coming out. This way you can postion the ends of these lines so they are pointing in a direction that you can loop a length of rubber hose to connect them. And you pretty much do the same for the 14mm and 17mm this is where im going to add my breather set-up, but you do not have to. I hope this was of some help
Modified by lsda9 at 8:56 AM 12/4/2007
Modified by lsda9 at 8:57 AM 12/4/2007
Modified by lsda9 at 8:58 AM 12/4/2007
Old Dec 3, 2007 | 05:29 PM
2slowGs-R's Avatar
just remove everything from the PS off and you can just leave it like that. You dont have to loop it around. Ive done it for my friends car and it works like a charm. I have the Padawan PS Removal Kit and Mine is so much harder to steer compared to my friends. THe softness of the steering depends on certain cars when the PS is taken off, plus the removal of the PS allows the engine Bay to look so much cleaner and feel more power from your vehicle's in hand.
Old Feb 8, 2009 | 09:59 AM
accord921153's Avatar
if i just cut the belt what will this effect
my power steering pump was smokin so if i just cut the belt what else will it effect
civicfreek22
10
Jun 22, 2021 07:20 AM
thevtecdisease
Jun 14, 2011 10:22 AM
boosted.da
Oct 9, 2009 02:41 PM
huge230
Aug 23, 2005 12:30 PM
Turbo Powa
24
Feb 15, 2003 06:37 PM
