installed skunk 2 IM and car doesnt start
Old Dec 2, 2007 | 02:56 AM
SupraRXZ's Avatar
Default installed skunk 2 IM and car doesnt start
ok so ive had problems before with my dizzy coil and stuff so i thought it was that that was causing my car not to start. I got a new dizzy (brand new) and it still wont start
my car - turbo eg, d16z6
first it was cause when i was swapping out my IM i pulled the map sensor accidently and pluged it in backwards, but i fixed that.(but not sure if its messed up)
so I crank the car and it sparks. but it doesnt stay on, dies in 1 sec.
sometimes when i get lucky and give it a little gas it stays on for about 5 secs but loses power and dies.
I switched out all the sensors from the old IM to the new one (which were all working and no CEL)
Im not sure what it could be.
Old Dec 2, 2007 | 03:01 AM
dangthemang's Avatar
Default Re: installed skunk 2 IM and car doesnt start (SupraRXZ)
hook up your spark plug wires in the right order?
Old Dec 2, 2007 | 03:07 AM
SupraRXZ's Avatar
Default Re: installed skunk 2 IM and car doesnt start (dangthemang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dangthemang &raquo;</TD></TR><TR><TD CLASS="quote">hook up your spark plug wires in the right order?</TD></TR></TABLE>
yup plugs are right(matched it with my bros stock eg), went down and tried it again and it starts up but only for a few seconds
Old Dec 2, 2007 | 03:28 AM
ukdmegg5's Avatar
Id say its got something to do with the map sensor
Old Dec 2, 2007 | 05:34 AM
Syndacate's Avatar
Default Re: installed skunk 2 IM and car doesnt start (ukdmegg5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ukdmegg5 &raquo;</TD></TR><TR><TD CLASS="quote">Id say its got something to do with the map sensor</TD></TR></TABLE>
Same, I'm not sure if it works like a MAF sensor, but if it does you'll basically lose stability (the engine will die) as soon as you disconnect that sensor. It's possible you messed it up when you plugged it in "backwards" - I'm pretty sure it only goes in one way.
Old Dec 2, 2007 | 06:41 AM
pythoner's Avatar
did you do anything with your fuel line or rail?
Old Dec 2, 2007 | 06:53 AM
PinoyDelSol's Avatar
* B A N N E D *
Default Re: (pythoner)
try some of that starter fluid spray?
Old Dec 2, 2007 | 09:40 AM
SupraRXZ's Avatar
Default Re: installed skunk 2 IM and car doesnt start (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Same, I'm not sure if it works like a MAF sensor, but if it does you'll basically lose stability (the engine will die) as soon as you disconnect that sensor. It's possible you messed it up when you plugged it in "backwards" - I'm pretty sure it only goes in one way.</TD></TR></TABLE>
Ya im pretty sure its that
I got a motorola 2.5 map sensor and it plugs the same way backwards
damn its my DD too
I wonder if theres any place i can pick one up locally
mish__
Dec 24, 2011 05:30 AM
Hondaciv95VX
Mar 21, 2007 07:53 PM
viprcr1
Feb 3, 2007 07:41 PM
e jay one
Mar 4, 2006 06:02 PM
