bulbs size on 98 accord instrument cluster
Pull out the cluster and see for yourself, instead of whining. You'll need to pull the cluster out anyway to change the bulb.
when someone can just tell me the bulbs size.. instead of me taking it out, see what bulbs,drive to the place buy the bulbs and then take out the cluster again and then change the bulbs.. and btw it not whining it asking..
holy **** haha
you bumped your thread like 20 times in a day, calm down
honestly if you went to Advanced Auto they have a book on the bulb aisle that tells you.
If you did 2 seconds worth of googling you'd find it as well
If you removed the 4 screws that hold the cluster in and looked at the bulbs yourself you'd have found it.
Not everyone is going to baby step your hand through stuff............
thanks.. well i did go to like 3 auto stores around here and they didnt have it or the book.. well if anyone didnt give me the answer i was just gonna take the thing out.. of course no one is gonna baby step but this is why they made this website to help people..
Are they Sylvania 74's or GE194's?
Here's a run down of the Sylvania bulbs for the car:
http://www.sylvania.com/Consum...s.htm
I used some 194 LED replacements in my dash - look good except the LED's are very directional and have bright spots vs. the omnidirection of the stock bulb.
I have a 2001 accord v6, so your bulb sizes are the same as mine. there are 3 sizes example the speedometer has a left and right side bulb size t10, this is a large size. there are like 6 t10's on that guage cluster. next you have t5 which is a medium size, thers a ton of those in there like 12 or so. next you have the small size which is t3, which is only used for your straight line of D N R D4 D3 D2 D1 sets these are tiny. like 6 or so of em. I tried to replace mine with led, biog mistake, look like sh337 and half of them were not working because led has a polarity so you have to play with it. it looked like crap so i just switched back but i still need a t5 cause my odometer bulb is burnt out. good luck. all else fails buy the bulbs at honda at rip off prices or go ebay. remember led= sh337
also pay attention to watt size, here s t5 i found on amazon, i also found a 12 watt t5 which must be wrong, not sure if 7 watt is still too high or what
12-Pack 12V 7W T5 Wedge Base Replacement Bulb, T5, Low Voltage, 12XT5-12V-7W - Light Bulbs - Amazon.com
The T5 bulbs referred to on Amazon are not for automotive use.
goldenmustache
Apr 15, 2009 04:11 PM
