can i build an h23 vtec like if it was an h22 like for allmotor
Old Dec 1, 2007 | 06:27 PM
low13da9's Avatar
Default can i build an h23 vtec like if it was an h22 like for allmotor
can you send me to the right places thanks
Old Dec 1, 2007 | 06:31 PM
xxmastermindxx's Avatar
Default Re: can i build an h23 vtec like if it was an h22 like for allmotor (low13da9)
there's a lot of info on it in a post in this forum, as well as the faq. hit search, put in h23 vtec, with or without spaces.
edit: here you go.
Old Dec 2, 2007 | 07:48 AM
Ghost 5.9's Avatar
word to the wise, stick w/ the h22 crank if you plan on revving high alot
Old Dec 2, 2007 | 08:51 AM
98vtec's Avatar
moderator emeritus
Default Re: can i build an h23 vtec like if it was an h22 like for allmotor (Ghost 5.9)
why?
Old Dec 2, 2007 | 09:13 AM
jdmlude5
Guest
Posts: n/a
Default Re: can i build an h23 vtec like if it was an h22 like for allmotor (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">why?</TD></TR></TABLE>
x2 i would like to see the answer to this.
Old Dec 2, 2007 | 10:19 AM
Ghost 5.9's Avatar
Default Re: can i build an h23 vtec like if it was an h22 like for allmotor (jdmlude5)
because h23 cranks are weaker and wont handle constant high revving. its best to go aftermarket for 95mm.
Old Dec 2, 2007 | 10:28 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghost 5.9 &raquo;</TD></TR><TR><TD CLASS="quote">because h23 cranks are weaker and wont handle constant high revving. its best to go aftermarket for 95mm.</TD></TR></TABLE>
weaker? um, no.
i think what you are trying to refer to is rod/stroke ratio. And its already been proven that you can still rev the **** out of the h23/f22 cranks, sorry.
rod/stroke ratio is a weak theory, imo.
Old Dec 2, 2007 | 11:00 AM
Ghost 5.9's Avatar
the h23 crank is definately weaker. i know a couple people who have broken them in high power apps as opposed to the h22 crank
for a race motor i would go w/ aftermarket.
for a street motor i would keep the rpms conservative.
Old Dec 2, 2007 | 11:06 AM
md23vtec's Avatar
haha no comment
Old Dec 2, 2007 | 11:36 AM
Apex1972's Avatar
Default Re: can i build an h23 vtec like if it was an h22 like for allmotor (md23vtec)
I believe I saw a thread about how to destroy a H23 VTEC or something. It has a few nice photos of a wrecked H23 crank. It was also not a half assed build from what I remember, can't recall who the lucky driver was though????
Ghost 5.9's Avatar
check w/ rosko, he can confirm
they tend to break while in the burnout box....its happened to a few of us
whats up roger
v gogunkergorilla v: trust me i have knowledge in this field. like i said, check w/ rosko i have a feeling he is not liking the h23 cranks either. or you could call a few pro's like the braunings. they stopped using h23 cranks when they first started out due to repetitive failures. btw, cant make anymore posts due to this trial thing, you know how it goes
Modified by Ghost 5.9 at 2:31 PM 12/2/2007
Old Dec 2, 2007 | 01:17 PM
gogunkergorilla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghost 5.9 &raquo;</TD></TR><TR><TD CLASS="quote">the h23 crank is definately weaker. i know a couple people who have broken them in high power apps as opposed to the h22 crank
for a street motor i would keep the rpms conservative.</TD></TR></TABLE>
If you talking about an h23 crank vs. a 98+ h22, then yes it is stronger. Your comparing 55mm mains vs 50mm, theres more material, less friction, more oil. If not, then bs. Every broken h23 crank I've heard of can be traced back to a bearing failure. If your breaking h23 cranks then you need to learn how to build a motor for high hp and high rpm.
Old Dec 3, 2007 | 05:10 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghost 5.9 &raquo;</TD></TR><TR><TD CLASS="quote">check w/ rosko, he can confirm
whats up roger
Modified by Ghost 5.9 at 2:31 PM 12/2/2007</TD></TR></TABLE>
Eh I have had pretty good luck with them once or twice . P.S. steve uses and H23 crank in his car and takes that bitch to 9,500
I guess to each his own. By the way do I know you ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogunkergorilla &raquo;</TD></TR><TR><TD CLASS="quote">
If you talking about an h23 crank vs. a 98+ h22, then yes it is stronger. Your comparing 55mm mains vs 50mm, theres more material, less friction, more oil. If not, then bs. Every broken h23 crank I've heard of can be traced back to a bearing failure. If your breaking h23 cranks then you need to learn how to build a motor for high hp and high rpm.</TD></TR></TABLE>
Agreed! The main thing that goes wrong if the motor is put together that is over looked is balance balance balance. When we do ours we dont just balance the crank, rods, and pistons. We also balance the crank pulley and flywheel / clutch assembly ( yes it can be done).
Old Dec 3, 2007 | 05:26 PM
98vtec's Avatar
moderator emeritus
&lt;3 1.49 r/s with ~9000rpm &lt;3
ha
Old Dec 3, 2007 | 06:00 PM
PrecisionH23a's Avatar
https://honda-tech.com/zerosearch
BrockNB
Aug 15, 2006 06:25 PM
crj_lll
Nov 11, 2004 08:37 AM
92hondalude
Oct 20, 2004 02:19 PM
hOndafienD 04
Jun 12, 2004 06:58 AM
shyboy_02
Sep 28, 2003 09:12 PM
