anybody hone their f22/23's themselves?
Old Dec 1, 2007 | 06:16 PM
xxmastermindxx's Avatar
Default anybody hone their f22/23's themselves?
building an f22/h23 hybrid that is about ready to get put together, and i'm wondering if you guys have honed your cylinders yourselves?
Old Dec 1, 2007 | 06:27 PM
gianinline's Avatar
Yes. I bought a honing machine at a local auto store, sprayed some water while doing it up and down with the hone attached to a driller. Came out with no problems!
Old Dec 1, 2007 | 06:34 PM
Default Re: (gianinline)
did you use just a regular drill? and how about the drill rpm?
Old Dec 1, 2007 | 06:35 PM
gianinline's Avatar
The driller had 6 different speeds.. we were doing speed #2... up and down.. up and down. Regular driller, yup!
Old Dec 1, 2007 | 06:41 PM
#2 as in 2nd from the slowest, right? i might take it in to get honed, but if i can do it myself, i'll just do that.
so i want to know any details/tips, and thanks for the fast replies.
Old Dec 1, 2007 | 06:46 PM
gianinline's Avatar
It's simple as hell.
#1 was the slowest, #6 was the fastest.
Hold the honing machine together and place inside the cylinders while you have to water running, only release them when there's water, otherwise... you might create scratches that you will have to hone to remove. Just work the driller up and down, and when you think it's good enough, and you have created the type of pattern inside the cylinders (only takes a minute on each cylinder wall), pull it out while spinning and then... stop the driller.... hold the honing machine together, place inside the next cylinder... add water... and start spinning.
You should give a try yourself... it's nothing crazy....
Old Dec 1, 2007 | 06:49 PM
cool thanks for the info. if i had a junk block, i would've gone ahead and tried it already lol. but all i've got as far as "junk" is an h23 that needs boring, and that has frm sleeves, and the frm honing process is a little bit different than iron sleeve honing to my understanding.
Old Dec 1, 2007 | 06:53 PM
gianinline's Avatar
No problem man!
yeah, if it needs boring, you need to take to a machine shop so it can be done with precision.
I'm out for today... peace out!
Old Dec 4, 2007 | 07:11 PM
chevy power's Avatar
Its usually less than 15$ per hole to hone cylinders. At least around my area.
Old Dec 5, 2007 | 03:53 AM
twkdCD595's Avatar
Default Re: (chevy power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chevy power &raquo;</TD></TR><TR><TD CLASS="quote">Its usually less than 15$ per hole to hone cylinders. At least around my area. </TD></TR></TABLE>
about the same here, which is cheap enough I would take it to a professional.
Old Dec 5, 2007 | 03:57 PM
accord99power's Avatar
Default Re: anybody hone their f22/23's themselves? (xxmastermindxx)
i have a newbie question when it comes to honing, is honing for the head? i thought boring is for the block and cylinders. is a port and polish of the head the same as honing?
Old Dec 5, 2007 | 04:59 PM
Default Re: anybody hone their f22/23's themselves? (accord99power)
a port and polish of the head is when your ports are enlarged/port matched to your intake and exhaust manifolds, and the interior of the head is polished to improve airflow.
boring cylinders makes them bigger in diameter.
honing cylinders gives them the cross hatch finish required for your rings to seat properly.
Old Dec 5, 2007 | 05:12 PM
ahh well said thanks for the info.
scotty13
Jun 4, 2019 06:40 PM
ejLday
Detailing
Mar 25, 2009 08:54 PM
BioXide02
Jan 12, 2004 05:09 AM
booscivic
Aug 4, 2003 11:05 PM
b18c5T
Jun 7, 2002 01:14 PM
