are jdm and usdm trannies the same??
My 97 crv's tranny is starting to go so i searched and found that i can get a jdm b20b complete swap with awd auto tranny for the same price as the junkyard wants for the tranny alone. Before i buy the jdm swap i want to make sure the tranny will work. Does anyone know? YES i did search first but didn't find anything conclusive.
Probably better luck in the CRV forums.
But for the most part if your CRV is OBDI and the motor is OBDI the electronics would be the same.
If you swap in an OBDI motor into your OBDII car most of the electronics are the same but you'd need to convert the ECU and what not.
OBDII into OBDII would be fine.
DelsoldS
11
Dec 7, 2007 04:57 AM
