Front passenger side wheel looks "off"
Old Dec 1, 2007 | 02:12 PM
Jooleeus's Avatar
Default Front passenger side wheel looks "off"
TL;DR version: What would make my front passenger side wheel look like this?
Background information: This is my 1989 Honda Civic DX. It came with a set of worn out eBay coilovers lowered to leave about a 1" finger gap between the body and wheels. Since this car is eventually going to be my mother's grocery getter, I switched out the coilovers for stock struts and springs. The fronts came pre-assembled and the rears were put together by myself with some assistance from a friend.
Despite having little experience with car work in general, the installation was fairly smooth. However, I was disappointed to see that the front passenger side did not match up with the other corners. It looks like there is about 1.5-2" difference compared to the rest of the car, and the wheel seems noticeably set back (caster problem?)
During installation, I didn't notice anything visibly bent among the various suspension components, but I feel that *something* has to be busted for the wheel to sit like that. Does anyone have any ideas as to what parts might be broken?
Old Dec 1, 2007 | 03:59 PM
boosstboy's Avatar
Default Re: Front passenger side wheel looks "off" (Jooleeus)
my friends ek had that problem. first we replaced lower control arm, then subframe, then upper only to replace the lower control arm again because the used one we got was also bad, problem fixed. so my gues is lower control arm, my friends was a caused by curbage from long time ago but wasn't that bad till we lowered his car, then looked just like that.
Old Dec 1, 2007 | 06:21 PM
Jooleeus's Avatar
Default Re: Front passenger side wheel looks "off" (boosstboy)
The car actually did hit something in that area at some point in time... guess the previous owner didn't fix it properly
Thanks for the input, I'll try to check it out sometime tomorrow once the rain clears up
Old Dec 1, 2007 | 08:01 PM
I CRX I's Avatar
i would also check the bushings or placement of the radius rods on the crossmember. i had the same issue with my crx and it turned out to be my radius rod was f$*&ed annnd the bushings were shot
Old Dec 1, 2007 | 09:21 PM
gnar kill's Avatar
Default Re: (I CRX I)
I have same problem from when I hit curb.... I replaced entire front suspension....it seems that the fron radius arm is putting pressure on the LCA pushing it back and it is not adjustable.; I would say get a new front cross member or do what I am doing and use it as an excuse to get a tractoin bar
Old Dec 1, 2007 | 09:41 PM
Hawkze_2.3's Avatar
Yeah your caster is off pretty bad. The radius rod is what keeps that in check, so look at the rod and also the the ends of it where it bolts to the LCA and the front crossmember. Also check the radius rod bushing...
Old Dec 2, 2007 | 05:30 AM
~sp33~'s Avatar
EFB055
Default Re: (gnar kill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote"> I would say get a new front cross member or do what I am doing and use it as an excuse to get a tractoin bar</TD></TR></TABLE>
Im sure his mum would love that lol.
Old Dec 2, 2007 | 09:30 AM
I CRX I's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">do what I am doing and use it as an excuse to get a tractoin bar</TD></TR></TABLE>Boy thats a great excuse isnt it?!?!? thats right up there with "MY motor is leaking oil, ......time to get a b-series........i swear sweety, getting a bigger motor in a smaller car saves tons on gas, it'll all pay off eventually!"
Old Dec 2, 2007 | 10:05 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I &raquo;</TD></TR><TR><TD CLASS="quote">Boy thats a great excuse isnt it?!?!? thats right up there with "MY motor is leaking oil, ......time to get a b-series........i swear sweety, getting a bigger motor in a smaller car saves tons on gas, it'll all pay off eventually!" </TD></TR></TABLE>
Exactly...
My zc was using a lot of oil....so I got a B16A.....hehe...but srsly,
Old Dec 2, 2007 | 04:13 PM
gnar kill's Avatar
lol...yeah I just got me ETD traction bar I won't have time to install it till after finals week but I will take pictures and do a write up on it to let you know if it helped.
Old Dec 2, 2007 | 07:55 PM
90B16A2's Avatar
Yea I had the same problem.. I just got another crossmember my bushing were shot.
Old Dec 2, 2007 | 09:08 PM
hai_tech's Avatar
could be the bushing not sure
Old Dec 2, 2007 | 11:44 PM
My_EFsedan's Avatar
Default Re: (hai_tech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hai_tech &raquo;</TD></TR><TR><TD CLASS="quote">could be the bushing not sure</TD></TR></TABLE>
i had that problem whe i got my sedan..turns out to be the radius bar..to the cross member..and no bushing!
Old Dec 3, 2007 | 04:23 AM
ludesrv's Avatar
MY firends 90 integra had the same situation. Turned out the front cross member around the radius rod had been pushed in, as if it drove into a rock or something. The whole cross member in the front was pushed in and had ripped open.
New cross member fixed it right up. Time for you to jack your car up as high as you can and start comparing both sides of the suspension. It will be clear what's wrong.
Old Dec 3, 2007 | 06:55 AM
BigDare23's Avatar
The same thing happened to me this summer after I broke an axle and it shot me into a ditch. My problem was my crossmember bolt holes were stretched causing the crossmember to shift back on one side. As a result my radius rod bent, LCA bent, and the opening on the on the subframe where the LCA connects became stretched. I replaced everything and got traction bars LOL
Old Dec 3, 2007 | 03:46 PM
Jooleeus's Avatar
Default Re:
Checked it out real quick earlier, and sure enough - the cross member is pretty beat up on the passenger side. I didn't notice it before because the radius rods looked okay, but now it's quite obvious that not all is well with my poor car. Looks like a trip to the junkyard is definitely in my future!
Also, you guys with the suggestions of getting traction bars for the grocery getter - funny Although I might consider it if the car passes down to me eventually, heh.
Thanks to everyone for the assistance, I really appreciate it!
junior_tm
Jan 7, 2016 07:29 AM
ththinh82
Suspension & Brakes
13
Nov 19, 2012 11:22 PM
jdmblu3s
Mar 21, 2007 11:44 AM
Soda Popinski
Apr 2, 2004 08:59 AM
SuPeR-TeG
May 2, 2002 04:49 PM
