92 DX Hatch w/ JDM H22 Issues...IACV
If this isnt the right place to post this thread..then mods please move.
Ok heres the situation, I've been working on this side project of mine for a few months...only a few hours every other wknd.
>Using a USDM P28 w/ a JDM H22 Map.
>All DX Wiring From the ECU to each individual sensor.
>Car Cranks but runs really rough.
Symptoms:
>Will not hold idle..
>After the Car cuts off.. a continual whining noise occurs from the IACV..
>NO CELS..
Overall I've done a lot of diagnostics...
I've cleaned the IACV as much as I could..
I've used other IACVs..
Checked for vacuum leaks...using the boost guage method, smokers method, and carb cleaner method.. (It appears that it could be leaking from the IACV.. when I spray the carb cleaner it revs up)..
BUT that doesnt explain whether or not the IACV is functioning when it should/shouldnt..
Any imput?
Symptoms:
>NO CELS..
Any imput?
89civich22
15
Sep 16, 2005 02:58 PM
