Need to figure out what each wire on the moonroof switch are and do.help.
Old Dec 1, 2007 | 10:34 AM
aser1z's Avatar
Default Need to figure out what each wire on the moonroof switch are and do.help.
Long story short, I bought a 94 rs completly converted to a 99 gsr even with installed moonroof. Had one of the alarms that rolls up the windows and closes the moonroof. Th alarm was taken of and all i have is the switch with the 4 wires coming out of the back and 2 wires coming from the moonroof.The 2 wire i believe are the open close signals. what else do i have to wire to the switch?would i just run a power to the other 2 spots on the switch? or is there also a ground?
Old Dec 1, 2007 | 03:45 PM
Blahblah718293's Avatar
Default Re: Need to figure out what each wire on the moonroof switch are and do.help. (aser1z)
if its an aftermarket moonroof, then nobody will know. rip out your headliner and see whats connected to what.
Old Dec 1, 2007 | 08:13 PM
aser1z's Avatar
Default Re: Need to figure out what each wire on the moonroof switch are and do.help. (Blahblah718293)
Its a gs-r moonroof. and the wires coming out of the roof are
yellow/red(down)
yellow/green(up)
but the gsr moonroof switch has 4 wire plugs in the back. So 2 of them are eliminated because of the ones coming from the moonroof but there still 2 empty spots.are those for a ground and power?if so where does each wire go to on the switch?
I also found an extra moonroof relay in my garage but don't know how to connect it to the moonroof.
Old Dec 2, 2007 | 01:16 PM
aser1z's Avatar
bump for help
Old Dec 3, 2007 | 12:27 PM
aser1z's Avatar
bump
Old Dec 3, 2007 | 01:09 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
The sunroof is a reverse polarity. the wires that you have listed switch from pos to neg for roll up and roll down. All you should have to do is match up the color were the unit was spliced in.
Old Dec 4, 2007 | 05:29 PM
aser1z's Avatar
Default Re: Need to figure out what each wire on the moonroof switch are and do.help. (wrx-killer-Sti-eater)
The problem is I can't. The O.G. owner took all the wiring off when he took out the alarm.
so I know i have the up and down signal wires now i need to know how to run the relay and exactly where each wire goes behind the 94 integra moonroof switch.
so now i guess i need to run a power and ground but don't know where they go on the switch.
Old Dec 5, 2007 | 09:06 AM
aser1z's Avatar
bump
Old Dec 5, 2007 | 09:54 AM
I'll do this. hit me up and I will help you get this done since your local.
Old Dec 7, 2007 | 09:13 PM
aser1z's Avatar
thanks for the help but im busy as ***.I have work, finals for school and lots of motor building.I do this on whatever spare time i have.
641iowaguy641
Jun 19, 2013 01:53 PM
JDMlude3189
Sep 28, 2009 06:06 AM
standbackimapro
Audio / Security / Video
Feb 21, 2007 07:38 AM
Simple
13
Jan 10, 2004 07:57 AM
Want2race
Jan 14, 2003 12:51 PM
