99 civic idles fine.. but doesnt want to rev up
Old Dec 1, 2007 | 10:30 AM
Silver89crx's Avatar
Default 99 civic idles fine.. but doesnt want to rev up
i just got the car to start after messing around wiht the dizzy and now its blowing out a little bit of white smoke out the exhuast.. first time its been started up n about 3 weeks.. and it does not want to rev up.. when i hit the gas it bogs down and goes up a lil bit but struggles.. can anybody help me with this problem.. its my daily driver and with out this i have no way to work or school..
Old Dec 1, 2007 | 10:56 AM
Default Re: 99 civic idles fine.. but doesnt want to rev up (Silver89crx)
can anybody please help me out?
Old Dec 1, 2007 | 11:26 AM
-JSpecEk*9-'s Avatar
what did you do to the dizzy?
Old Dec 1, 2007 | 11:28 AM
Default Re: 99 civic idles fine.. but doesnt want to rev up (-JSpecEk*9-)
just messed with the wires inside of it.. becuz a couple weeks ago i put a new coil in it and it must not have been gettn a good connection or sumthin with the green and yellow wire so i jsut pushed wiggled aroudn with it..
Old Dec 1, 2007 | 11:29 AM
did you mess with the timing? check engine light on?
Old Dec 1, 2007 | 11:34 AM
yea the lights on.. it was throwing a code 9 before it started to mess up as bad as it is now.. i havent checked it since ive got the car to start up again
Old Dec 1, 2007 | 11:38 AM
5) Back in the driver's seat, turn the key to the 'ON' position. The CEL light will come on at startup, like normal, but it will then begin to flash.
**By counting the number of flashes, you can decipher the CEL #.
SHORT flashes are single digits (1/2 second)
LONG flashes are 10's (1 second)
-----CEL # List-----
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
go check it again and see how manys codes you got.
BaSikMuSic
16
Feb 27, 2012 08:38 PM
managon_5
15
Feb 15, 2010 11:34 AM
sicmon
Jun 3, 2009 09:02 AM
LigerZeroWPC
Aug 28, 2006 12:01 PM
grneyez
13
Jan 6, 2004 05:49 AM
