Suspension & Brakes Theory, alignment, spring rates....
sounds from the under ground
Old Dec 1, 2007 | 06:18 AM
assassinACE12's Avatar
Default sounds from the under ground
i own a 96 honda civic ex i bout it with a nasty set up of kyb and some no name springs (2.5in -3.00in drop)i plan to rasie it with tein springs but now theirs a nosie comeing from the front driver side wheel it makes a radle nosie when i hit a bump or the car bounces up i have replaced inner and outer tie rods so far.
will a tein drop be wize to do with kyb any pic of a tein drop i dont want to go to low 2in max?
Old Dec 2, 2007 | 11:25 AM
wreckeddc4's Avatar
Default Re: sounds from the under ground (assassinACE12)
your shocks are probably beat, the noise is because there is no more dampening in the shock, and it is topping out against itself, all the cars i have seen with kybs have blown shocks, they are not really designed for lowered cars, just as a better shock at stock height.
Episode
Suspension & Brakes
Oct 14, 2010 09:06 AM
dc5 paoer
Jan 7, 2006 08:38 PM
cilvia
Suspension & Brakes
13
Aug 20, 2005 09:47 PM
HYPEBEAST!
Suspension & Brakes
Apr 10, 2005 12:34 PM
