FS: 91' DA9 GS Integra.............BUILT MOTOR..............
Old Nov 30, 2007 | 10:10 PM
SuperiorSC's Avatar
Default FS: 91' DA9 GS Integra.............BUILT MOTOR..............
1991 GS INTEGRA
$7000 obo..... NOT INTERESTED IN TRADES>>>>>> CASH ONLY!!!
BLK/TAN
17800miles on chassis
1000miles on motor
Specifications
Chassis Code: DA9
Curb Weight: 2560lbs
Engine
Engine Code: B18A1
Type: Inline-4, aluminum block and head
Internal Modifications: 0.25Over sized ITR Pistons, LS rods, LS crankshaft, Steve's Machine BIG RACE ported PR3 head, Insane Racing Stage2 Camshafts(skunk2 copy), STR cam gears, Cometic Head Gasket, ARP studs (Brand new OEM oil pump, water pump, rear main seal Main/Rod bearings, ALL new oem gaskets)
Drivetrain Modifications: A1 cable Short gear LS trans, Exedy Street disc/pressure plate, ACT 8lb Street lite flywheel
External Modifications: DC 4-2-1 header, JG Victor X Port matched intake manifold, Professional Products 68mm TB, AEM intake, HKS Super intake
Engine Management Modifications: PR3 ProSpeed ECU, high volume fuel pump, RC Engineering 320ccinjectors x 4, STR Fuel Rail
Valvetrain: DOHC, 4 valves per cylinder, BluePrint/Import builders valvetrain, BluePrint/Import builders titanium retainers, bronze high rev valve guides, 3 angle valve job
Displacement: 1846cc
Compression Ratio: 11.0:1
Horsepower: Approx. 200whp (91 octane)
Redline: 9000rpm
Suspension Modications: CUSTOM APEXi N1 Pro Dampers (custom made by Eric Hsu) -rebuildable dampers!
Wheels/Tires: 14x6 Sprint Hart CP's, Falken Ziex 912 205/60/14
Interior Modicifaction: HKB Hub, Nardi wood gain Steering wheel, Alpine headunit, JL audio W3 10" subs x 2
*PICS WILL BE UP SOON*
Modified by SuperiorSC at 10:03 AM 12/1/2007
Old Nov 30, 2007 | 10:41 PM
thatnikkashoD's Avatar
pictures?
Old Nov 30, 2007 | 10:43 PM
I doubt you'll be able to even get 5 for it.
Old Dec 1, 2007 | 09:03 AM
SuperiorSC's Avatar
Default Re: (thatnikkashoD)
and NO LOW BALLERS!!!
Old Dec 2, 2007 | 03:52 PM
SuperiorSC's Avatar
Default Re: FS: 91' DA9 GS Integra.............BUILT MOTOR.............. (SuperiorSC)
jDMJeRk
Aug 16, 2009 02:07 PM
civic4lif
Oct 28, 2008 07:11 PM
civic4lif
Aug 28, 2008 11:40 AM
Wangbu
Jan 15, 2008 12:27 PM
wade
Oct 4, 2003 12:05 PM
