d16y7/z6 pass smog?
Old Nov 30, 2007 | 08:50 PM
d1nki's Avatar
Default d16y7/z6 pass smog?
will a a y7/z6 mini pass smog with a chipped p28 ecu? i have an es oval, header, intake. I can get a stock header, intake and exhaust but will it pass if i get the parts? my car is untuned also.
Old Dec 2, 2007 | 12:18 AM
jdmsir96's Avatar
Default Re: d16y7/z6 pass smog? (d1nki)
nope ur car has to be bone stock.. unless u get sum sweet hook-ups...
Old Dec 2, 2007 | 12:40 AM
denraweb's Avatar
Default Re: d16y7/z6 pass smog? (jdmsir96)
Doesn't have to be bone stock, but parts need to be CARB, and since that swap is a frankenstein, it's not CARB. I have heard of people adjusting the timing to pass smog or whatever, but I don't know how that works. But from what I know (experience), a mini me will not pass.
Old Dec 6, 2007 | 07:41 AM
Tomdata's Avatar
Default Re: d16y7/z6 pass smog? (denraweb)
that car will pass at 95% of smog shops. most guys can't tell the difference on cars like this. Don't trip. just make sure the timing is set to 16*, the car is warmed up and the check engine light is not on. If it fails scan the failure report and post it on this thread so I can see what they failed it for.
Old Dec 6, 2007 | 07:54 AM
Ser1N's Avatar
Default Re: d16y7/z6 pass smog? (Tomdata)
what timing is stock i thought it was 12 im just wondering why 16 myself, i got a y7/y8 that im going to try to smog too.
Old Dec 6, 2007 | 08:45 AM
thesmogman's Avatar
The motor itself should. The question is the ECU. Most of the time the chip add's gas and timing.... well too much and a fail is in your future.
We do not check the ecu. It is not a requirement. I would go back to stock or the stock settings.
Make sure you have a good cat on there also.
I also believe the spec for timing is 12 btdc. I would stay there for the first test.
This we test/check.
Old Dec 6, 2007 | 12:24 PM
Tomdata's Avatar
Default Re: d16y7/z6 pass smog? (thesmogman)
Sorry correction set timing to 12DBTC
cvc1393
13
Jul 19, 2009 12:54 PM
jiggatone
Sep 17, 2007 05:27 PM
PePpeRedDc5
May 4, 2005 08:01 PM
91civicEX
Nov 9, 2003 09:40 PM
Grandma Humper
Jan 9, 2003 01:13 PM
