Suspension & Brakes Theory, alignment, spring rates....
CRX Ef suspension onto EG
Old Nov 30, 2007 | 08:30 PM
kiddcarbuff's Avatar
Default CRX Ef suspension onto EG
i searched for over an hour with mixed results, a friend of mine just wrecked his 91 crx w/ koni yellows groundcontrols and extended top hats, everything was jsut put on like 3 weeks ago, i was jsut looking for a yes or no before i buy it off of him, will it fit my EG? i know i need to use my EG shock forks right? but the rears are the same 89-00 so that isnt the issue, im jsut looking for an answer regarding the fronts. with the correct fork setup
Old Dec 1, 2007 | 09:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Koni North America shows different part numbers for the front shocks for 91 CRX and 92-95 Civic, but it shows the same part number for the rear shocks.
My guess is the front shock body lengths might be different.
Old Dec 1, 2007 | 11:38 AM
hmh alright. i know the eg forks are the same height as the ef forks but the Ef forks have a smaller inner diameter. so idk would i run ef forks,. im getting the setup for 350$ so im desperatly trying to figure out if its gonna work
Old Dec 3, 2007 | 10:32 AM
A.E Motoring's Avatar
Default Re: (kiddcarbuff)
u need to run EF forks, i have done it before, i tried using EG forks with a EF shock, doesnt work.
Old Dec 3, 2007 | 01:56 PM
N2HIFI's Avatar
Default Re: (Dual Cam Racing)
it will work just fine , no issues at all . Just use the EF forks on the EG and adjust the ride hight accordingly to get the car to sit at the height that you want it.
just be careful of the rear LCA bolts .. they tend to break if they have never been removed or replaced. If you can get your buddies LCA's also and bolts this will help make the swap easy. Worst case if he needs suspension in return just loosen the inner and outer LCA bolts and leave the shocks attached and remove them as one piece and put the new stuff on, would make the swap super easy and less chance of bolts breaking
chris
Old Dec 3, 2007 | 04:09 PM
hey thanks guys, all i needed to know
Old Dec 6, 2007 | 02:31 PM
Db1_77's Avatar
^ word to your mom
-jonathan
724chris
Jan 10, 2010 06:40 PM
724chris
Dec 16, 2009 10:47 PM
89dohcEF
Nov 8, 2003 11:58 AM
Lightning Lover.
Sep 28, 2003 03:26 PM
egghead
Dec 17, 2001 04:59 PM
