itr cams
Old Nov 30, 2007 | 07:39 PM
VTECdohcter's Avatar
Default itr cams
would i be able to run itr cams with stock gsr valvetrain or no?
Old Nov 30, 2007 | 07:42 PM
sc95delsol's Avatar
Default Re: itr cams (VTECdohcter)
yes as long as it is gsr vtec yes
Old Nov 30, 2007 | 07:51 PM
Default Re: itr cams (sc95delsol)
so i shouldnt have to change anyone else
Old Nov 30, 2007 | 07:56 PM
serio_ENDLESS's Avatar
it all depends what year head you have cause the 2000 gsr already have type r cams in the heads...
but if it is older yeah you can use them also do a valve adjustment to be safe
Old Nov 30, 2007 | 07:58 PM
Default Re: (serio_ENDLESS)
i have a 99
just incase anyone else got any thoughts
Old Nov 30, 2007 | 08:10 PM
Default Re: (VTECdohcter)
Bump!!!
Old Nov 30, 2007 | 08:13 PM
yeah it should run good just still do the valves for insurance
Old Nov 30, 2007 | 08:28 PM
ight just valves or valves springs and retainers
Old Nov 30, 2007 | 08:44 PM
Ruben19's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by serio_ENDLESS &raquo;</TD></TR><TR><TD CLASS="quote">it all depends what year head you have cause the 2000 gsr already have type r cams in the heads...
but if it is older yeah you can use them also do a valve adjustment to be safe</TD></TR></TABLE>
not true!
00 gsr dont have itr cams stock.
Old Nov 30, 2007 | 08:48 PM
.PLUMMM's Avatar
I'm sure it would work but I would still recommend dual valve springs and retainers just for precaution
Old Nov 30, 2007 | 08:52 PM
94eh2's Avatar
Default Re: (.PLUMMM)
mike just get them...they will help out alot..and no you dont have to upgrade your valve train just do a valve lash/adjustment like previously stated...
Old Nov 30, 2007 | 10:58 PM
TRi*EK4's Avatar
Default Re: (94eh2)
should be no prob
Old Dec 1, 2007 | 12:12 AM
baulum's Avatar
Will not reqiure dual valves or retainers,but it depends whether you are keeping your redline stock.If you extend your redline across 8500 rpm then dual valves springs and retainers need to change.
Old Dec 1, 2007 | 12:19 AM
503_EF9's Avatar
Default Re: (baulum)
itr and ctr are both mild enough cams to run stock valve train
type r cams did not come in any gsr of any year
if you can find some ctr cams id go with those. both of the non vtec lobes feel the same as the gsr the difference is seen in vtec type r cams a a bit of a step up and ctr cams are even slightly more agressive then the stock cams.
youll be fine with either.
Old Dec 1, 2007 | 03:26 AM
pimpinblackcivic's Avatar
as above, i run itr cams on stock valvesprings and retainers for over a year fine
Old Dec 1, 2007 | 06:41 AM
Default Re: (503_EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 503_EF9 &raquo;</TD></TR><TR><TD CLASS="quote">itr and ctr are both mild enough cams to run stock valve train
youll be fine with either.</TD></TR></TABLE>
so ur saying ctr cams will be better
Old Dec 2, 2007 | 02:34 PM
503_EF9's Avatar
i personly like ctr cams better.
the non vtec of ctr and itr is almost identical but the ctr vtec lobe is a bit more agressive.
also the skunk stage twos are almost an identical regrind of the ctrs so whichever you can find cheaper.
Old Dec 2, 2007 | 04:35 PM
i fond itr cams with skunk2 camgearsfor 250
Old Dec 2, 2007 | 05:18 PM
devney's Avatar
Why would you say some stupid non-sense like this?
Old Dec 2, 2007 | 09:23 PM
503_EF9's Avatar
definatly a good deal
get em
sell em for more and grab some ctrs
Old Dec 2, 2007 | 10:45 PM
93egSLEEPER's Avatar
ITR's will work nicely with a stock valvetrain... thats what i have.
Old Dec 2, 2007 | 10:56 PM
503_EF9's Avatar
Default Re: (93egSLEEPER)
haha there was supose to be a hint of humer in my post.
itr is definatly a nice grind and for 250 who would say no i just think both ctr and itr parts are highly overpriced for what they are and if i was to go buy 300-400 dollar cams id rather have something that is quite a bit more agressive then stock.
Old Dec 3, 2007 | 11:05 AM
how much power am i loooking at with gsr on i/h/e and itr cams and skuck 2 cam gears on a tune
Old Dec 3, 2007 | 11:29 AM
fmrprojects's Avatar
i"ve done it many times. and just cause you have itr cams dont rev it anywhere past 8200
Old Dec 3, 2007 | 11:36 AM
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">i"ve done it many times. and just cause you have itr cams dont rev it anywhere past 8200</TD></TR></TABLE>
i rev it know to 8500. how much power am i loooking at with gsr on i/h/e and itr cams and skuck 2 cam gears on a tune
