Need help ASAP!!!. Broke a Motor Mount Bolt
Old Nov 30, 2007 | 06:40 PM
jimmyfloyd182's Avatar
Default Need help ASAP!!!. Broke a Torque Mount Bolt
ok, I decided to install Energy suspension motor mounts in my 96 GSR. I started taking the driver's side off and I got the back bolt off fine.
When I went to do the front bolt, I got it out 3/8ths of an inch then it got hard to turn. I gave it about a 1/2 turn and there was a pop as if I broke the head off the bolt. When I looked, I saw this:
The head was still there, but the whole thing truned and moved freely. Upon looking further, I realized that I broke the nut that is welded INSIDE the frame rail loose. And, to top it off, there is no way to get into the frame rail other than those two holes shown.
Does anyone know how I can get this bolt out and a new one in? I need to get this done before monday when i have to work again.
Thanks
Modified by jimmyfloyd182 at 11:39 AM 12/1/2007
Old Dec 1, 2007 | 10:40 AM
No one can help?
Old Dec 1, 2007 | 12:40 PM
God-Driven's Avatar
I hate rust on cars it makes it so hard to work on them you have to be extra carefull on every bolt you turn.
And about your problem about the bolt I broke the nut inside the rail like you did on my friends car and he didnt really case so we just put one and let it roll like that sorry I cant give you no advise.
Old Dec 1, 2007 | 04:59 PM
LSracing94's Avatar
Default Re: (God-Driven)
i cant see **** of this picture
but drill it out?
Old Dec 1, 2007 | 09:20 PM
gsr dood's Avatar
Default Re: (LSracing94)
honestly the only way your getting that out is if you cut the rail a tad bit and get a hold of that nut.
drilling anything isnt going to help
Old Dec 1, 2007 | 09:21 PM
gsr dood's Avatar
Default Re: (gsr dood)
get a hold of a highpowered air chisel and chisel the **** until the head breaks.
or take an angle grinder and eat the **** outta that head!
good luck
LillDragun
Oct 17, 2012 05:55 PM
germanturtle
Nov 13, 2011 07:42 PM
rhennin
Suspension & Brakes
12
Apr 12, 2007 12:16 PM
Ronin150
Nov 17, 2004 09:21 AM
DMF
Oct 13, 2003 06:25 AM
