Huge List With Crazy Low prices for Gsr/ls Integras and d16Z6 vtec civic in ohio CHEAP
GSR 94 teg parts>
Edlebrock 65 mm tb $250 Shipped!! http://columbus.craigslist.org/pts/456833653.html
Premium gsr turbo flange $50 Shipped!! http://www.bmcrace.com/product...id=81
Discontinued WW 1/4 thick urthane front lip for 94-97 teg $80 bux not shipping
All Black parts>
i have quite a few black door panels..im for more info
$40 ac mount
$20 upper aluminum dr's mount
$150 shipped Full OEM gsr headgasket and mani set
$110 shipped p72 gsr virgin ecu
$50 shipped gsr slight polish valve cover http://columbus.craigslist.org/pts/455343260.html
$35 shipped gsr ac compressor
$35 shipped gsr ac condensor
$15 shipped each gsr pwr steering brackets
$15 shipped speedo bezel x's 2
$10 shipped pass side door handle/lock bezel x's 2
$15 shipped E brake handle
$55 shipped CF gas lid
$55 Carbon Fiber shifter surround
$115 Shipped upper and lower steering column parts (clamshell) in Carbon Fiber
$35 Shipped moonroof switch/vent x's 3
$10 shipped each rear speeker grill x's 2
$50 moon roof assembly Not shipping unless your giveing me like $200
$30 front sway bar
$30 rear sway bar
$15 shipped rear dome light
$40 shipped clutch slave and pedal
$65 shipped gsr mc/booster
$60 shipped each airbag x's 2 sets
$30 bux each bare dash...have 3
$25 shipped under steering wheel plastic part x's 2
$55 shipped 98 ls cluster
$70 shipped gsr cluster
$40 shipped master window switch
$35 shipped dr's headlight (94-97) same on pass side
$90 upper radiator support cut off x's 2
$30 front crash bar x's 2
$35 shipped rear hatch struts
$50 shipped rear blk cargo cover/tray
$35 shipped on the abs unit x's 2
$50 steering column/$150 with wheel and airbag
$50 each airbag (have two full sets in blk)
$20 shipped srs unit with wires
$30 each bare blk dash...some wear not shipping
$35 stock gsr intake
$40 shipped each tail lightw/harness $60 shipped for both http://columbus.craigslist.org/pts/436850083.html
$20 shipped 98+ brand new black turnsignals
$50 FIRM each Both WHITE doors mint with windows
$50 FIRM one Red pass door Mint with glass
$35 RED rear filler part under tail lights...has gsr badge Pics> http://columbus.craigslist.org/pts/442397806.html
$150 Rear red hatch with spoiler/ glass
$30 Pass red Fender MINT
D SERIES PARTS>
D16z6 swap> unknown milage...Does run ( have a video)
no clutch left in it...comes complete minus harness and p28
$400 bux....$300 if you dont want the tranny
LOCAL PICK UP ONLY Located in columbus ohio
$15 shipped each 2 d15b7 maps
$20 shipped Z6 map
$25 shipped z6 iac
$25 shipped z6 starter
$30 shipped T brackets
$90 Good head 90k miles $120 shipped Pics>
http://columbus.craigslist.org/pts/455342325.html
$25 eg seat rails
$10 each motor mount (have a box full)
$65 distributer or $70 shipped
$110 shipped z6 engine harness uncut
$100 head and block UNKNOWN condition pickup only
$25 z6 oil pan or $35 shipped
$20 bare intake mani or $35 shipped.
$175 shipped Full AC for 92-95 civic
$30 shipped no name upper header
$30 stock intake
$25 shipped each i have 3 tb's 2 look like from z6...other is slightly larger im guessing y8
$55 shipped y8 distributer
all are d series.
$80 shipped this has the higher red line......not just the tach
lmk what milage you want it rolled to
$70 shipped a non si speedo with tach,both are 5 speeds
$25 shipped ex door tweeters
$10 shipped dock lock switch
$100 shipped black/grey pwr ex door panels
$50 eg core support cut
$55 set of eg healights and corners shipped
$150 Red stripe del sol seats in good condition Pick up only http://columbus.craigslist.org/pts/495288875.html
Prices include shipping if it says "shipped" otherwise its + shipping or pickup only
if there is a " x's 2 " after the parts i have two of them or two sets
Located in columbus, ohio Large items like the full motor or body parts i WILL NOT SHIP if its small and you want to pick up the "shipped" price becomes cheaper!
Pretty Firm prices....Because they are allready hella cheap..The onll stuff i need on trade are a teg airbag tray, H2d parts, d series lsd.
PICTURES CAN BE HAD BY ONLY EMAILING ME AT mx6trickout@aol.com
Modified by Fibercation at 6:04 PM 12/1/2007
All Black parts>
$40 ac mount
$30 front sway bar
$30 rear sway bar
D SERIES PARTS>
$20 shipped Z6 map
$25 shipped z6 iac
$25 eg seat rails
$30 stock intake
all are d series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fibercation »</TD></TR><TR><TD CLASS="quote">Willing to do trades for H22 Stuff</TD></TR></TABLE>
i need H.....Will trade B lol
4real
4real
